Starters , what kind and how much ??$$$. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Like Tree3Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Starters , what kind and how much ??$$$. in Past Cadillac Vehicle Discussion; Pulling anything above 14.5 volts indicates either a shorted cell in the battery or a faulty voltage regulator....
  1. #16
    Feb 2003
    california
    69
    6,611
    Re: Starters , what kind and how much ??$$$.
  2. #17
    ELDO GUY's Avatar
    ELDO GUY is offline Cadillac Owners Fanatic
    Automobile(s): 2K ELDO WHITE DIAM , 2K TURBO BUG ,69 VETTE ZZ4 2014 CTS
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Engine starts instantly after 2nd try although starter does sound a little weak . Would a slight strobe effect (barely noticible) of the headlights be a indication of a faultly voltage regulator ?
  3. #18
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Quote Originally Posted by ELDO GUY View Post
    If this occurs reliably, this also supports our solenoid contacts theory....
  4. #19
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Just a follow up. I tested the battery after a few trips around town and the voltage was about 11,96 so I went to COSTCO and exchanged my battery turns out it was 3 and half years old. I paid 63 dollars originally. got 42 bucks back and found it the new battery for was 81 bucks. I so much for the warranty. So far no issues but the temp is warmer here will be back in the teens later this week so we will have to see what happens
  5. #20
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Well guess what, its pretty dam cold here and my problem is back looks like I'm gonna have to replace the starter. I plan on using the quick method. Any problems with proping up the back of the intake like its been discussed here ? TX.
  6. #21
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,871
  7. #22
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Tx. Mine is a 2000 and difference on this one ? can I still prop it up and do you have to remover the fue line with the special tool Tx. for the help
  8. #23
    68
    81,755
    Yours is basically the same, but you have a steel fuel rail so you may not get away without disconnecting it. Don't forget to relieve the fuel pressure before disconnecting it.
  9. #24
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    2 things, I was wondering how to remove the wires from the fuel injectors. I removed the Grey plastic lock in but the wires won't come off I don't want to force anything. It seems like when the weather is warmer the problem goes away. I what's that about. It is can't be the battery it's new! Tx
  10. #25
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,566
    You remove the gray safety locks and then depress the injector connector safety clip.
  11. #26
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    I'm at work now but, is that the blue clip on top of the injector where the wires run through the Tx
  12. #27
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    I'm gonna try and get this done tommrow. I was looking at this and was wondering if the fuel line and wires to the injectors were removed could the manifold and injector rail be moved as 1 piece?
  13. #28
    68
    81,755
    I believe it can.
  14. #29
    98cadillac is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Seville STS
    Feb 2013
    306
    When my starter was going bad, I had the same issues, except I had to turn the key many times near the end for it to start. I was able to find a "new used" starter at a junkyard for $10.00 (i.e., someone had replaced the original already). After I replaced it, it started like a new car.
    On my 98 Seville STS, I didn't remove any wires from the injectors. After I disconnected the fuel lines (and whatever else was in the way), I just removed the intake manifold as one piece with everything attached.
  15. #30
    ELDO GUY's Avatar
    Sep 2004
    SKOKIE ,iLL
    66
    446
    Just a few closing comments on this one! The starter replacement is really not that difficult. Almost any one in this forum could probably do it. It looks more than it is. On my 2k eldo I found it necessary to remove all the componets because there was not enough room for the manifold to move back and forth . Althought not mentioned in the FSM it was necessary for me to remove the 3 bolts in front of the throttle body to allow the manifold to come straight up. Some have suggested that it isnt necessary to replace the manifoild gaskets but by visually inspection of the old ones I would say your asking for trouble . it took me about 3 hours , but i was disturbed a few times . If i did it again I could do it in 2 . Turned out the positive post comming out of the solonoid was loose causing a intermittment bad connection .
  16. Remove Advertisements
