Post new radiator install, temp issues - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
Cadillac Seville / Cadillac Eldorado Forum Discussion, Post new radiator install, temp issues in Past Cadillac Vehicle Discussion; Got it booked in, to have a coolant system flush, explained the issue and history, they said they hook it ...
  1. #46
    curlywurly is offline Cadillac Owners Fanatic
    Automobile(s): 1999 STS & 1992 STS
    Jun 2011
    OKC
    118
    Re: Post new radiator install, temp issues
    Got it booked in, to have a coolant system flush, explained the issue and history, they said they hook it up to a machine specially made to do this.
    Just noticed, the pressure cap says 15 psi, the one I have coming says 18 psi (ACDelco RC87), 15 psi ones do not seemed to be readily available, I'll leave the old on for now.
  2. #47
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,340
    Quote Originally Posted by curlywurly View Post
    it looks like RC98 is the delco part number for the 15PSI cap -
    but your car should have the RC87 - 18PSI cap -
  3. #48
    Jun 2011
    OKC
    118
    Definitely says 15 on the current cap on the car, I've never changed the cap, and the previous owner (friend of the family, maintains most of vehicles himself), says he has never changed it, so a mystery. Up to the point I changed the rad out, the 15 psi cap seems to have worked fine, as did the cooling system, even in OK 100F summers the temp gauge hardly ever went pass the 12 mark.
    Also, the RC87 cap looks identical to the current one, the RC98 looks different, not that looks mean much, just saying...
  5. #49
    68
    81,883
    If I take it to a shop (most likely) is a power flush different from a regular flush?
    Yes it is. A flush is simply running fresh water through the system. A power flush does it with a flush gun under pressure. Based on everything you said, I think I would lean towards a power flush, but that's just me.
  6. #50
    Jun 2011
    OKC
    118
    Okay, new pressure cap fitted and things are much better now, the old cap must have been faulty, so far so good.
  7. #51
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,829
    Good to know. Thanks.
  8. #52
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    Quote Originally Posted by basscatt View Post
    you want it flushed - not just a regular drain and fill -
    I am a former shop manager and let me give you one piece of advice.
    WATCH them hook the machine up and do the flush.
    It does not matter if you know what they are doing or not, just be sure they hook the machine up.
    I have had mechanics working for me in the past who did a drain and flush (against my orders) because they thought they could get away with it due to the fact that they were lazy and didnt want to hook the machine up.
    Just my $.02
  9. Remove Advertisements
