What goes in this rectangular hole?
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Cadillac Seville / Cadillac Eldorado Forum Discussion, What goes in this rectangular hole? in Past Cadillac Vehicle Discussion; Hi Everyone, I'm new to the Caddy forums. I just picked up a 02 Eldorado ETC from a dealer who ...
    txtaz is offline Cadillac Owners Fanatic
    Automobile(s): 72,92,02 Eldorado
    Jan 2013
    55
    185
    Hi Everyone,
    I just picked up a 02 Eldorado ETC from a dealer who was going to wholesale it because of mechanical problems. I made an offer, they countered and I have a new project to work on.
    This is my third Eldorado. My Grandfather gave me my first two. Both restored, well almost. Still working on the 92 a bit but almost completed.
    So far with the 02, I've re-built the front brakes, torsion bar links, fixed a shorted #4 injector wire and a loose intake manifold. It is running pretty good for what was planned as a rebuild. I honestly thought I'd be putting in a remanned based on what their mechanic told me. Now it's running great. Still a little rough on idle, but I'll get there.
    My question is...
    Who knows what goes in this rectangular hole on the firewall? (Circled in Red) I have it taped up so the air does not blow out.
    The moisure barrier is shot and needs a new one. The dealer can get it for $177. Any better options for this part?
    Does the moisture barrier have a fitting that covers this hole in the 02 ETC or is there a module I'm missing? There are two screw holes for something to go in the hole.
    I have the GM service manuals coming, yup the ol' school ones...on paper.
    Thanks for the help.
    Taz
    98Geldog is offline Cadillac Owners Fanatic
    Automobile(s): 1998 eldorado, 2000 Catera
    Dec 2010
    Chicago
    247
    Think that's just a cut out to see the evaporator. With a new one the hole won't be there
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,686
    Re: What goes in this rectangular hole?
    actually -
    that's where the blower motor resistor USED to be located -
    when the Eldo had one - the blower speed controls are built into the blower on this year -
    yes - there should be a cover plate over that hole -
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    That is normally not cut from factory, is one piece with the firewall plastic cover and there is a note on it: CUT TO SERVICE.
    Jan 2013
    55
    185
    Nice, Thank you.
    Sounds like the new moisture barrier will cover this hole.
    Is it normal for the moisture barrier to fail after 10 years and 55,000 miles?
    I was shocked at how brittle it is. It's obviously from the right bank(even) exhaust header heat over time.
    Maybe wrapping the header would help the new one last longer.
    Any thoughts?
    Thanks,
    Taz
    69
    82,269
    If by "moisture barrier" you mean, what I call the HVAC housing (#8), yes, it is common for them to get brittle over time. I'm surprised that the dealer can get it. I had heard that they where no longer available and can't even find a part number for them at gmpartsgiant or Nalleygmc. I assume you know that the engine has to be removed in order to replace it?
    Jan 2013
    55
    185
    Hi Ranger,
    Thanks for the info.
    Moisture barrier was the term the dealer parts guy used and said he could get one. I've searched out part numbers also and did not find anything.
    Yes, #8 in the diagram, however I think mine only covers the passenger side.
    My plan is to get the part and decide to pull the motor or not.
    I might have a good diy write up for this, let's see if I get the part first.
    Taz
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,476
    Is that still the same black cover as the 90s Devilles and STS, Eldorado had that always breaks up and falls apart? I had the chance to get a perfect one for mine but it was too much work to be bothered changing. I finally patched it up last fall.
    I think mine has a removable door covering that hole.
    69
    82,269
    Yup, that's the one.
    Jim 99 eldo's Avatar
    Jim 99 eldo is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado 2000 Jeep TJ 2000 Ford SD 4X4 Diesel crew cab
    Dec 2009
    Norco, California
    51
    372
    Looks like an easy fix with some resin and fiberglass followed by some flat black paint.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    basscat is correct
    the original N* HVAC system had a blower motor control module that plugged into that spot but the second design HVAC system used a blower motor with the controls built into it
    they decided to keep the same housing cover part to service both old and new and the new ones would just need the cover
    the cover is GM#52472473
    around 1997 model year they changed the housing cover to not have a hole in it
    Jan 2013
    55
    185
    Thanks everyone.
    I just got the new cover, it came in over night by the dealer. Wow!
    It is part #89019293 for $160.78.
    It looks like it will go in without pulling the motor. I'll take pics when I get to it.
    Ordering part GM#52472473 first.
    Thanks.
    taz
    69
    82,269
    When did that change come about Chris? What about the pre-Northstar Devilles? Which one did those use? I can't recall.
  16. #14
    Sep 2007
    Wilmington, NC
    13,969
    If have to check. I think it was closed up on 1997 models. I know K-body 4.9L models did have that same style box as their N* siblings but before '93/'94 I'd have to check.
  17. #15
    69
    82,269
    OK. I asked because I distinctly remembered that resistor module (even changed one) on the mid '80's Eldo's, but can't recall if my '92 Deville had it or not.
  18. Remove Advertisements
