Results 1 to 3 of 3
Thread: Is it a bad ground - 1992 Eldorado electrical problems
    damon416 is offline Cadillac Owners Member
    Automobile(s): 1992 Eldorado
    Oct 2012
    9
    I have a 92 Eldorado. when I turn on my lights the door chime comes on and stays on. I have no reverse lights, my power antenna does not work, my power trunk motor does not work and my passager side turn signal light is brighter then the other so is the brake light. And sometime I am not getting enough power to the engine. Is this the result of a bad ground wire? if so, where do I start looking to correct the problem? Thanks
    pocketpared is offline Cadillac Owners Fanatic
    May 2009
    200
    Re: Is it a bad ground - 1992 Eldorado electrical problems
    I have a 92 Eldo and I don't think I've ever noticed a door chime. When I turn the key off and the headlights are on I get a warning chime then. As far as the other problems, I don't know about that.
    emmettW is offline Cadillac Owners Member
    Sep 2014
    39
    10
    Hey, in your owners manual towards the back, there is a detailed list of what each fuse under the hood and in the trunk compartment do, check the list and see if anything adds up, you may have a blown or corroded fuse, but it certainly could be a ground issue too, but I'd recommend first check the fuses.
  • You may not post replies
