Leaking sunroof
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Leaking sunroof in Past Cadillac Vehicle Discussion; So, my car gave me an early Christmas present; water under the back seat, traveiling via the sunroof drain tube, ...
    Eldorado guy is offline Cadillac Owners Fanatic
    Automobile(s): '80 Eldorado, '50 Chrysler Windsor, '92 Ford F-250 7.3 4x4
    Jun 2006
    26
    112
    Leaking sunroof
    So, my car gave me an early Christmas present; water under the back seat, traveiling via the sunroof drain tube, behind the driver side sail panel. With help from previous posts on the forum, I narrowed it down to sunroof drains, earlier today. I tried running .08 weed wacker line through the tube. That didn't solve it. I resorted to pulling the whole back seat, removing the seat belt retractor, removing the sail panel, and pulling the head liner back slightly to see what's going on. Water is draining out of the drain tube fine, and it isn't leaking around the nipple at all. I even pulled the line off and rodded out the drain hole at the channel. However, around the corner towards the back about three inches from the drain itself), it's leaking right off a zip tie.
    If the drain isn't plugged, why is it leaking? I can see that I'm probably going to be dropping the whole headliner to fix this (oh joy), but I don't understand why it's leaking of the tube isn't plugged at all (the end in the trunk is clean, I can blow air by mouth through it easily).
    This is a bad leak and I can't let the car back out into the rain unitl it's fixed. The Eldorado won't smog and the Chrysler is a 4000 lb colender itself, so I'm out of vehicles. Any ideas?
    Thanks and Merry Christmas,
    Dan
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Re: Leaking sunroof
    What if you plug that one drain till you have the time to fix it?, then if possible park your car to direct the flow to the 3 remaining drains,when I was having same problem with my 92 eldo I didn't plug drain, but always parked the drain higher than the rest of them. Worth a shot.
    Jun 2006
    26
    112
    Re: Leaking sunroof
    I think I may have found a blockage. I rodded it out, but the car is going to sit until tomorrow when I'll reassemble everything. I'll let you guys know how it goes.
    Thanks,
    Dan
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    Re: Leaking sunroof
    When I had this problem I discovered that the rear lines were smashed by the electric panel behind the rear seat. This happened at the factory. Seems the first owner noticed that it "rained" inside the car, but was unable to get it fixed. I did fix the problem, but since the tubes were once crushed, I am apprehensive every time the car gets wet. I have had no problems since, but when you have 5 gallons of water under and in the carpet, and the leather in the back seat gets damaged from water, you are cautious. I have other posted in my user name describing this problem and a good fix.
    Jun 2006
    26
    112
    Re: Leaking sunroof
    Lifer,
    funny that you mention that. While I reassembled the car yesterday morning, I noticed a wiring harness had that line crushed at least 50%. It was still flowing a pretty good stream even like that, but I resituated things a little and I'll hope for the best. I haven't noticed any more water down the pillar, so hopefully it'll stay that way. I'll have to look at your posts on this and learn something.
    Thanks,
    Dan
  8. Remove Advertisements
