What to look for next?
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, What to look for next? in Past Cadillac Vehicle Discussion; Okay my 92 STS 4.9 is doing somethign really really weird. It will randomly not start. Does not seem to ...
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Okay my 92 STS 4.9 is doing somethign really really weird. It will randomly not start. Does not seem to be theft system related. What will happen is you will turn the key security light goes out all dash lights, everything else functions but no crank. I tried the starter enable relay which I found to be rewired in the car and at first the ground was in a horrible place. So I reattached it to a solid spot and for a month not one issue.
    Today yet again it wouldn't crank, the only remedy it seems is to let the car sit and eventually it will start right up and even starts right back up when you cut it off. The theft system works because one of my girls got fingernail polish on the chip and it clearly displayed "Starting Disabled For 3 Minutes". This problem shows no signs of that. Randomly I will have to hold the key in the crank postion for a few seconds for it to start cranking.
    Is there something that maybe when hot is causing this? Possible way to bypass all of this and straight wire it all?
    Feb 2003
    california
    69
    6,664
    Re: What to look for next?
    Start with the basics. Load test the battery to confirm its OK, then clean the cables where they attach to the battery. A load test will verify the battery's ability to handle a big load like a starter trying to rotate an engine. You say yourself, the theft deterrent system is working correctly so why wire around it?
    Jul 2012
    Richmond, VA
    40
    181
    Confirmed battery is okay, confirmed vats is working properly, and it seems all tests go back to the starter relay circuit. That is what I want to wire around.
    With that said I am using my FSM to diagnose all of this. It happened to me a month ago I don't know now if it was coincidence or just it had sat long enough but I jumped pins 1 and 4 on the starter enable relay and it fired right up. The FSM said if that worked to check the ground and thats when I found it connected to the stud of the back seat and rerouted it to a better ground. And until yesterday it hadn't shown any signs of the problem again. The worst part is both times it has left me stranded is without any testers so I am not able to find what is or isnt working when it messes up. Maybe one day it will do it when I'm home.......
    Jul 2012
    Richmond, VA
    40
    181
    Meant to post solution to this, turns out the starter solenoid which even though has a heat shield is right by the exhaust manifold was getting hot and the contacts were stuck open until it cooled down.
    SliceOfLife is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 Seville SLS, all black--261,000 miles
    Mar 2007
    Borderline rural Michigan
    62
    934
    Quote Originally Posted by Crudsturbo View Post
    Whoda thought! Better late than never, Crudsturbo!
    Jul 2012
    Richmond, VA
    40
    181
    So lo and behold after starter replaced it happened again turns out after taping on the nuetral start safety switch she fired right up. Will be changing it real soon here.
  9. Remove Advertisements
