what are power steering fluid specs for 2001 STS - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Cadillac Seville / Cadillac Eldorado Forum Discussion, what are power steering fluid specs for 2001 STS in Past Cadillac Vehicle Discussion; Yeah, that ^^^. Kendall HYKEN hydraulic oil (good P/S fluid) is a 10W dino oil with a bit more anti-foam ...
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Re: what are power steering fluid specs for 2001 STS
    Yeah, that ^^^.
    Kendall HYKEN hydraulic oil (good P/S fluid) is a 10W dino oil with a bit more anti-foam additive. Works in logsplitters, too.
    19999
    , Don't sweat it. Buy a quart of a P/S fluid that says "Meets GM specs" or whatever, use the turkey baster and over the course of a month suck out and replace the P/S fluid 8 ounces at a time. Rags and care.
  2. #17
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    394
    Thank you all. I will change fluid on weekend and will share my experience.
  3. #18
    oldstuff is offline Cadillac Owners Fanatic
    Automobile(s): 66 convert-93-96-97-97-99 Eldorados
    Nov 2013
    McCleary Wa.
    81
    460
    Ranger is right on with this one. Transmission fluid is also hydraulic fluid. It is non foaming and has worked well in steering systems since they were introduced in passenger cars. A lot cheaper too. I've dumped 10w motor oil in a power steering pump with no reprecusions. Drive out in the grass and turn your wheels lock to lock a few times to remove any air, you don't need to jack up. When you hit the end keep pressure on the wheel a couple seconds at each end.
    Dave
    I know I'm gonna get beat up for this, but P/S fluid is simply hydraulic fluid (oil). If you sucked it out before starting the car I doubt you hurt anything. Draining and refilling certainly won't hurt anything, but I'm not really sure it's necessary.
