FSM - What are TORQUE Specifications for STS 2001 for Wheel Bearing replacements
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, FSM - What are TORQUE Specifications for STS 2001 for Wheel Bearing replacements in Past Cadillac Vehicle Discussion; Does anyone have FSM to share what hat are TORQUE Specifications for STS 2001 for Wheel Bearing replacements: 1. To ...
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    394
    1. To tighten the wheel bearing and hub retaining bolts, what should be torque in ft pounds
    2. For Axle nut, what should be the torque
    Thanks
    John
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Hub flange bolts - 96 ft/lbs
    Axle nut - 118 ft/lbs
    Sep 2003
    Metro ATL
    4,854
    Re: FSM - What are TORQUE Specifications for STS 2001 for Wheel Bearing replacements
    Hub and bearing bolts = 96 lb ft.
    Drive axle nut = 107 lb ft.
    What is a FSM?
    Sep 2010
    East Boston MA.
    29
    26,325
    Factory Service Manual. And l the numbers I posted are from mine.
    Sep 2003
    Metro ATL
    4,854
    I stand corrected on the axle nut torque value in post #3. The 109 lb ft came from a '98 Seville Service Manual. Checking my '04 Deville Service Manual I find the 118 lb ft value.
    The word "Factory" does not appear anywhere on the covers of the 3 different GM product Service Manuals currently in my library.
    Sep 2010
    East Boston MA.
    29
    26,325
    Most people use the term "Factory Service Manual", when referring to the manual used by a dealer service department, as opposed to inferior parts store repair manuals (such as Haynes or Chiltons).
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    From the 2002 GM/Helm manuals........... click and zoom...............also posted down in Cadillac Tech Tips............
  10. Remove Advertisements
