2001 SLS. Need help with codes!
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 SLS. Need help with codes! in Past Cadillac Vehicle Discussion; i am searching for them i cant find anywhere with a list of all the codes these are what popped ...
    Gonjafishing is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Seville SLS 4.6L 32V North*
    Nov 2012
    Edmonton AB
    22
    40
    i am searching for them i cant find anywhere with a list of all the codes these are what popped up i have no warning lights on my dash i assume all is well but i just want to make sure.
    ABS C1288
    DDM B1328
    DDM U1713
    IRC U1016
    TTM u1016
    Also i did have my cps code come up but it went away i am going to change the crankshaft position sensor soon
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,545
    Re: 2001 SLS. Need help with codes!
    Always add the suffix to each code - Current or History. It makes a difference.
    U codes are voltage and data transmission hiccups.
    This link is in the proper year sequence in the "How to pull codes" sticky ^^^^
    http://myweb.accessus.net/~090/dtcobd2.html
    Nov 2012
    Edmonton AB
    22
    40
    Woops they are all "history"
  5. #4
    Feb 2006
    55,545
    Your engine has two CranKshaft Position sensors (CKP) - an upper and a lower, B & A. Pictures in my albums. Not fun. CKP codes are P 0335, P 0336, P 0385, P 0386 plus a few circuit codes.
    For codes and how it works ....... Suppose a fault is detected in CKP A - a code of P0335C sets. If the fault is a total CKP failure the engine defaults to "Limp Home" mode - fixed ignition timing, and you should get a SES light. BUT, if the fault is transient - a hiccup - then the code stays Current for 3 more ignition-run cycles even if the fault is not again detected. After 3 successful start-run cycles during which the fault does not appear the code changes to History, where it remains for 30 more start-run cycles, and if the fault does not appear during that time the code then self-clears from the memory. (Different modules have different numbers of checks necessary to self-clear codes from History)
    During a normal commuter/shopping week you will start/stop the car about 25 - 30 times, so it's entirely possible that a non-critical code could set on Monday morning, go to History, and be gone by next Monday.
    Many, many codes come and go like clouds - you get into a habit of "pulling codes" for no reason at all and you will go stir crazy trying to figure out where and why they all appear/disappear. I used to "pull codes" once a month and write them all in a log - after a year of that stupidity I quit. Haven't gotten into the system in over 2 years. No reason to.
  6. Remove Advertisements
