2003 sls heated seats
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2003 sls heated seats in Past Cadillac Vehicle Discussion; They stopped working. Check fuses or what? Battery is new so that isn't the problem....
    ARTSBEST is offline Cadillac Owners Fanatic
    Automobile(s): 2003 SLS
    Jul 2005
    318
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    They both stopped working at once? Do the lights come on on the buttons?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    Re: 2003 sls heated seats
    Turn the key On. Press a seat heater button and listen down low under the front seat apron. An intermittent click indicates the seat pad or back heater element has opened - the module is trying to close the circuit, but "sees" infinite resistance.
    Otherwise, check the fuses - both underhood and under rear seat pad boxes, an d check the under-seat connectors to the heater modules.
    There is a new design heater element in the field - dealer - and the least expensive install is to use a good upholstery shop if you doin';t attempt DIY.
    Some have disassembled the seat and pads to find the element break, and then soldered a small jumper across the break, but that doesn't seem to last very long.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,874
    if everything else fails - check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  7. Remove Advertisements
