Battery not charging, replaced alternator, 2 weeks later same problem
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, Battery not charging, replaced alternator, 2 weeks later same problem in Past Cadillac Vehicle Discussion; I have a 2000 SLS, 2 weeks ago I began getting the System Charge, battery not charging message. Using this ...
    BIGJOHN826 is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS
    Oct 2011
    19
    I have a 2000 SLS, 2 weeks ago I began getting the System Charge, battery not charging message. Using this site, I decided it was probably the alternator and had it changed. I replaced it with a OEM refurbished alternator. Everything ran fine for 2 weeks, now I'm getting the System Charge, Battery not charging message again. I have searched this forum and read just about every thread related to this issue, but have not been able to come up with a list of possible culprits outside of it being the alternator again (which it very well, could be). You guys help is greatly appreciated.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,560
    Re: Battery not charging, replaced alternator, 2 weeks later same problem
    if you have not already done so -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Oct 2011
    19
    There were a ton of codes, I don't know if they have ever been cleared. So Im posting just the current codes for now. Thanks
    ABS C1233 right front wheel speed circuit open
    ABS1246 C1246 Break lining wear circuit open
    DDM B2220 left door switch stuck in lock
    DDM B2221 right door switch stuck in lock
    DDM B2242 memory exit switch failed
    DDM B2243 memory set switch failed
    IPM B1343 Air inlet door movement fault
    IPM B1983 Device Power Circuit Low
    IRC B1327 System Voltage Below 9.0
    MSM B1327 System Voltage below 9.0
    PCM P0141 Heated oxygen sensor circuit bank heater performance bank 1 sensor 2
    PCM P0300 engine misfire detected
    PCM P0420 catalyst system low efficiency
    PCM P560 System voltage
    PCM P0731 Incorrect first gear ratio
    PCM P1381 misfire detected no communication with brake control module
    RSS C0662 level control exhaust valve circuit low
    VTD B1327 System Voltage Below 9.0
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Check battery cable connections are tight and free of corrosion. How old is the battery?
    Oct 2011
    19
    The battery is a year old. No corrosion on the battery itself, its under the back seat. I need to check the other end of the wires though.
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by BIGJOHN826 View Post
    You have several modules reporting low system (as in battery) voltage. When the battery voltage falls below 9 Volts, various modules become unreliable and can and will set trouble codes in error.
    If it was my car I would address the low battery voltage issue before I worried about the long list of trouble codes.
    Oct 2011
    19
    I noticed that too, but I assumed that may have been because the battery ran down when the first alternator went bad.
    rodnok01's Avatar
    Feb 2012
    NC
    6,673
    Wouldn't think a battery that went bad would last another two weeks after changing the alt, but checking it would be easier than a new alt. A bad cell can keep a battery from charging.
    Oct 2011
    19
    Gotcha. It certainly wouldn't hurt to check it. Thanks
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    Can u check voltage while motor is running? If alt is not working, what is condition of battery now? Do u have it on charger? Did u change alt? Or shop? Does it have warranty? I have seen bad replacement alts?
    Feb 2003
    california
    69
    6,679
    Have the replacement alternator tested. I would have done that even before posting. I think you simply have a defective replacement. If that fixes the problem, erase ALL the codes. Then check for codes a week later.
    The Gold's Avatar
    The Gold is offline Cadillac Owners Fanatic
    Automobile(s): 92 El Dorado
    Jul 2010
    San Francisco
    125
    Read on some thread that these Caddys need AC/Delco alternators. Some third wire thing.
    Other brands don't work.
    Make sure your 'OEM part' is truly so.
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    My alternator went bad this week as well. I'm replacing it with a brand new 200 amp unit from Summit Racing. only 170.00 including tax. I"ll be tackling the problem as soon as it comes in (special order). Anyone have any experience with Summits alternators??
  16. Remove Advertisements
