Need Help with a code C0584 on a F55 suspension
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, Need Help with a code C0584 on a F55 suspension in Past Cadillac Vehicle Discussion; Ok my 2002 STS keeps setting a code of C0584. Now to start with I had about 15 differant codes ...
    rocketvette95's Avatar
    rocketvette95 is offline Cadillac Owners Member
    Automobile(s): 2002.5 Cadillac Seville STS with FE3,F55
    Jun 2012
    Western NC
    49
    96
    Ok my 2002 STS keeps setting a code of C0584. Now to start with I had about 15 differant codes and most of them were to the EBTCM. I replaced the EBTCM and now all of the codes are gone except this C0584. So I went to ALLDATA found the test for this code,found out it is for the left rear RSS sensor, and it is not really any help. So I went and switched the sensors from right to left just to see if the code would switch sides. After a short drive came home tested it again and still have the same C0584 it did not switch sides.
    So from what I have read I think what has happned is the RSS has gone into the Soft ride defalt. Does anyone know of anything else that could be the problem. I have priced the rear shock and retail from a dealer is $1008. for a SHOCK. So I have called a few of the local salvage yards and when I tell the I need the rear shock for a 2002 Seville with the FE3 and the F55 suspension they think I am crazy! I even called Cadillac Heaven and he told me he had never heard of the F55 option code.I have been on Ebay with no luck.
    Do you guys thing I am in the right area. DOES ANYONE KNOW A YARD OR A SOURCE TO FIND THESE VERY RARE SHOCKS?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: Need Help with a code C0584 on a F55 suspension
    Talk to Chris in Parts at Rippy Cadillac over there >>>>
    RockAuto lists the F55 shocks (in the "original ride quality") for your car at about $650.
    The F55 struts and shocks are tough - and hardly ever fail...............
    C 0584 refers to the Right Front solenoid circuit Open - check your strut, electrical connector, wiring harness. ALLDATA's DTC links group several C codes, including this one, into the FRONT STRUT diagnostics.
    Use this for handy reference - bookmark it..............
    http://myweb.accessus.net/~090/dtcobd2.html
    Jun 2012
    Western NC
    49
    96
    Submariner409,as bad as I hate to do it,I made a BIG BIG mistake. For some reason I keep thinking it was a left rear shock code. Man i feel like a dumb a$$. So I will start over and see where I end up
    Thanks
    Again
    Well Me being the moron that I am fiqured out the problem. If I would have pulled the wheel and found the strut unplugged. The worst part is I changed the oil yesterday and caught myself looking at the front end for any issuses,maybe this is why I dont turn wrenches for a living.
    Now this car rides and drives like it is suppose to
    Again Thanks to Sub409
