transmission cooler line question -2003 sts
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Cadillac Seville / Cadillac Eldorado Forum Discussion, transmission cooler line question -2003 sts in Past Cadillac Vehicle Discussion; My upper tranny cooler line that goes into the upper quick connect fitting of the radiator has play and is ...
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    My upper tranny cooler line that goes into the upper quick connect fitting of the radiator has play and is leaking (wiggles any direction) the quick connect is new it came with the radiator.yes I made sure its in all the way before putting the snap ring thing on the connector.does the metal line that goes in the quick connect get wore out ? Maybe the quick connect that came with the radiator is the wrong size,Idk but it wasn't leaking before I change the radiator.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    This is the upper cooler line, you can see someone cut the line and put a hose and clamp.just trying to figure out why the upper cooler line has play in it.
    jamie1 is offline Cadillac Owners Member
    Automobile(s): 1998 STS
    Apr 2012
    63
    71
    Re: transmission cooler line question -2003 sts
    I can't see from the pic, but the upper fitting in the radiator of my son's '99 is held in by a spring clip. I'm ASSuming yours is the same. Move the rubber collar away from the fitting, (it covers a spring clip), use an awl, pick and/or a small screwdriver and lift the clip off of the fitting. The tube will now come out. Replace the 'O' ring, put the clip back on the fitting first, then 'pop' the tube back in. There is some play in the fitting/tube, it's not solid like the lower one that screws in.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Maybe that's the problem there isn't a plastic collar over the fitting.when when I took the cooler line off my old radiator I didn't see an o ring there was a washer with a rubber coating that the cooler line went through.
    Apr 2012
    63
    71
    Quote Originally Posted by sts 03 View Post
    That's the one, rotate and push it back, away from the radiator. Underneath is the fitting and spring clip.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Yeah I got that part but I think when I had the tranny replace the guy cut my cooler line and lost the plastic retainer that goes over the quick connect.I might just buy a new cooler line that comes with the plastic retainer.maybe I didn't put the clip in right, cause it wasn't leaking before I changed the radiator and the plastic retainer thing wasnt over the connector then.anybody changed the upper tranny cooler line, how much of a pita is it to change?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    U changed radiator and trans? No reason to expect any leaks on line.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    The leak started after I changed the radiator its leaking from the upper cooler line where it goes into the radiator.the cooler line that goes into the quick connect has some wiggle play.the line is in all of the way but still wiggles.i'm wondering if the quick connect that came with the radiator is the wrong size
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    What is this black piece on the upper cooler line.there is one on each side.also how much pressure should it take to push the line in the quick connect
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Any ideas on the black plastic piece is on the cooler line on the pic
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Had anyone changed the upper tranny cooler line , the one that connects to the top part of the radiator and wraps around to the back/right side of the tranny? Besides the air intake does anything else have to be removed? also is the supposed to be a bevel washer that goes on the end of the cooler line.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    That plastic piece goes over the "quick connect clip" so it doesn't pop out.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Quote Originally Posted by maeng9981
    That's what I was thinking but this one looks different then the other plastic retainers I've seen.
  16. #14
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Also isn't there some type of rubber washer that goes in the quick connect before the line goes in?
  17. #15
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No washers, just an O ring.
  18. Remove Advertisements
