engine start only with accelerator
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, engine start only with accelerator in Past Cadillac Vehicle Discussion; Engine have problem with start,only start with acclerator.if not acclerated engine rotated,started and stopped.now i clear codes 027.any idea what ...
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    Engine have problem with start,only start with acclerator.if not acclerated engine rotated,started and stopped.now i clear codes 027.any idea what is to check?
    68
    82,070
    Re: engine start only with accelerator
    Not real familiar with that engine anymore, but it is obvious that the throttle plate is not being held open, thus choking off the air intake. It's an idle speed adjustment. Just not sure how that engine does it. Standby, someone will chime in.
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Doesnt that car still have some type of IAC? I know it at least has an eltric carb on it if not tbi.
    68
    82,070
    Not sure how the idle is controlled on that one (set screw, ISC motor, solenoid). Been a long time since I've seen one.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The 4.5 uses an ISC motor.
    Rixky-D is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado ETC
    Oct 2011
    Midlands in SC
    83
    Cleaning the throttle body ought to be the first thing.
    68
    82,070
    Then that's the problem. Either it is inop or out of adjustment.
  10. Remove Advertisements
