Results 1 to 4 of 4
Thread: how to install window drive motor on 1990 cadillac seville
    wetsie29 is offline Cadillac Owners Member
    Automobile(s): seville
    Sep 2012
    5
    I would like to get istructions on how to install a drive motor for a 1990 cadillac seville on the driver's side front window.Please help if you can.Thank you!
    69
    82,262
    Re: how to install window drive motor on 1990 cadillac seville
    Have you checked the Tech Tips section? Might be something in there.
    pocketpared is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Eldorado
    May 2009
    200
    I just did my 92 Eldo not too long ago. I took the door panel off and it was sitting there held in by 3 screws. Simple. The drive gear positions itself when you mount the motor. Unless someone else comes in and says on your model it's complicated, I'd just take the door panel off and have a look. It really was very easy.
  5. #4
    BDCadillac is offline Cadillac Owners Member
    Automobile(s): 1990 Cadillac Seville
    Aug 2012
    28
    9
    I just put new 5.25 inch speakers in the front doors of my Seville, some clips around the door panel pry them out, remove 2 Philips screws by the door pull handle located under some slider caps, the Philips screw under the steel snap cover located under the door open handle. The door panel should just slide off. O yaa also 2 screws located on the side of the door panel. So once you have the door panel off just examine it for a while and take that old motor out and install your new one. I hoped that helped a little with taking the door panel off.
  • You may not post replies
