Help!! :(( Near Stall & SES Light On
Results 1 to 8 of 8
Cadillac Seville / Cadillac Eldorado Forum Discussion, Help!! :(( Near Stall & SES Light On in Past Cadillac Vehicle Discussion; My 2001 el dorado had the feeling like it was going to stall , then later on the check engine ...
    catalina08 is offline Cadillac Owners Member
    May 2012
    12
    My 2001 el dorado had the feeling like it was going to stall , then later on the check engine light came on ......
    Crudsturbo is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Seville STS & 1991 Sedan Deville
    Jul 2012
    Richmond, VA
    40
    181
    Re: Help!! :((
    Pull the codes, there is a sticky above if you don't know how. Also when you get them look up the defenitions and post them. That will be needed to help you.
    68
    81,727
    Re: Help!! :((
    P.S.
    I edited your title to be more descriptive.
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,249
    Re: Help!! :(( Near Stall & SES Light On
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
  6. #5
    May 2012
    12
    Ok cool I'll try that now.
  7. #6
    May 2012
    12
    Ok I got a lot of weird codes , an while in the process my car again almost stalled . Here's some of the codes :
    PCM?
    Ipc b1983 history
    Ipc u1152 history
    No acm code
    No tcd code
    No cup code
    Idc b2721 current
    U1255 history
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,249
    Quote Originally Posted by catalina08 View Post
    PCM?
    Ipc b1983 history
    Ipc u1152 history
    No acm code
    No tcd code
    No cup code
    Idc b2721 current
    U1255 history
    it is customary to post the definitions of any codes you might have -
    because no one has them all memorizes -
  9. #8
    68
    81,727
    Use the OBDII link in the DTC sticky to decipher your codes if you do not know where to go for that.
  10. Remove Advertisements
