gas smell and one simple question
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Ranger
  • 2 Post By Submariner409
Cadillac Seville / Cadillac Eldorado Forum Discussion, gas smell and one simple question in Past Cadillac Vehicle Discussion; There is only one "lever" or linkage to the sensor that you would have to play with to keep the ...
    69
    82,272
    Re: gas smell and one simple question
    There is only one "lever" or linkage to the sensor that you would have to play with to keep the shock fully inflated.
    No, there is no rear seat or trunk access on your car. One common leak point is the filler pipe. They tend to rust out. Check it to be sure fuel is not leaking and running down the pipe, but that usually only happens after a fill up.
    69
    82,272
    #16 is the "lever" (link) you are talking about. There is only one under the rear end, not one on each wheel. I don't think there is any adjustment on it. You may have to manually adjust the sensor (#15) and leave the link disconnected.
    Not sure what to tell you about the leak. Only a close inspection will tell.
    http://www.gmpartsgiant.com/Page_Pro...-013&SortKey=8
    padgett1963 and padgett1963 like this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,829
    Make a folder named something like "CF Resizes" and put it in your car files folder. Put your digital pics and diagrams from sites in the resizes folder. The site is limited in upload space, so open your pics in something like a Windows picture manager and resize them to 800 by 800 or just a tad smaller.
    In your working thread you will see a tab in the lower right corner - "Go Advanced". Click it and use the browse tabs to surf to your resizes folder, click on the desired picture, hit "Upload" and when it finishes close the upload window, Submit Reply.
    Using this method you are limited to 20mb of picture space and multiple uploads in the same post will load as thumbnails - this is done in order to save CF server space.
    You can also load attachments from third party picture storage sites.
