2001 STS: Changing antifreeze (Dexcool, evacuation)
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2001 STS: Changing antifreeze (Dexcool, evacuation) in Past Cadillac Vehicle Discussion; I'm going for an antifreeze flush tomorrow for my 2001 STS. I put in the red dexcool stuff last time, ...
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    I'm going for an antifreeze flush tomorrow for my 2001 STS. I put in the red dexcool stuff last time, but the rad shop is insisting I should get away from it (they refuse to put any in)....so
    1) Should I stick with DexCool? Or use their generic long-life stuff?
    2) They do NOT remove the lower rad hose, they just evacuate the system with a machine. Is that ok? Better/worse?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    DEX-COOL, or the all makes, all models "green stuff", it doesn't matter which you use, just change it every 2-3 years.
    You'll never get ALL of the coolant out of a Northstar during a coolant change, even if you remove the lower hose. It's not necessary anyway. The point is to replenish the anti-corrosive additives, and a simple drain and fill will do that.
    What type of "machine" is this shop using? Does it just remove coolant, or is it some sort of "flush" machine? If so, go somewhere else.
    ocgltd's Avatar
    Oct 2008
    London Ontario
    300
    Re: 2001 STS: Changing antifreeze (Dexcool, evacuation)
    Not sure...I didn't ask. Is a "flush" machine a bad thing? (and why)..
    Sep 2010
    East Boston MA.
    29
    26,323
    Well if we were talking about a transmission fluid flush, a flush is (potentially) a very bad thing. There's no telling what contaminants were in the fluid of the vehicle that was last hooked up to the machine. That's not nearly as big of a problem with a cooling system, but flakes of rust and leak stop products from other cars aren't the best thing for your car either.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    It might be instructional to Google "automotive vacuum coolant flush machine" to find out the fluid removal/replacement process. None of the work involves recycling fluid from another vehicle, and a transmission "flush" will not get the dust and chunks out of the pan: that's what a pan drop/cleaning is for.
  8. Remove Advertisements
