code P 0135 - 2002 Eldorado
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, code P 0135 - 2002 Eldorado in Past Cadillac Vehicle Discussion; Have 2002 Eldorado, #1496 Code po135 is present, 02sensor Heater Circuit Bank 1 sensor. Car has always stayed at the ...
    ELDO 02 #1496 ETC is offline Cadillac Owners Member
    Automobile(s): Eldorado 02 ETC #1496
    Jul 2011
    5
    Car has always stayed at the 12 oclock on temp. gauge. Wants to move up towards 1 oclock, can above code cause this type of problem.
    Thank
    You
    68
    82,081
    Re: code po 135
    No, an O2 sensor failure will not cause a temperature rise. Start by checking the purge line to be sure it is clear and flows coolant.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,267
    Re: code P 0135 - 2002 Eldorado
    When does the temp gauge needle "move" - under what conditions of car operation: traffic, idling, road speed, HVAC On or OFF ?
    The gauge needle should move a bit to the right when in heavy traffic or simply sitting still, idling, with no A/C function set.
    Take a look at the annotated temp gauge in my albums for how and when fans and thermostats work. Click my username, open the profile. Left column, 2 albums, 6 pages of FWD Northstar stuff and parts for your engine.
    Jul 2011
    5
    Re: code po 135
    Thank you Ranger
    It was great talking with you a couple of weeks ago, I had called and asked about the speed sensor, that was the first code that showed. I cleared the code and drove a little and now code 135 shows. Going to replace the 02 sensor on bank I. I have read other post inregards to replacing, but am not sure on how to tell if it is the one before the cat. or behind it?
    I am not sure, but the temp. gauge rising to about 1 oclock could have been from using the HVAC, this is the first time I had used it. The temp. gauge would fall back to 12 oclock when moving on the open road.
    Am new at posting, but plan on telling about my 2002 ETC on a later date.
    Thanks for you response.
    ELDO 1497
    Jul 2011
    5
    Thanks for you reply Submariner409.
    I used the HVAC for the first time and will see if that could have caused the rise in temp. I also pulled up your annotated temp gauge, thanks. The caddy has never ran hot, with all the problems that others have had I keep a constant eye on that gauge.
    Going to replace the 02 sensor, per reading previous posts bank one is on the left, farthest from the fire wall. How do you tell if it is the one before or after the Cat?
    Again thanks for you input, I have been reading all the post for sometime now, but have never posted. Hope to post more about my Caddy later.
    ELDO 1496
    Feb 2006
    56,267
    In the 2000 - 2004 Northstars there are 3 O2 sensors.
    Left (front) bank exhaust manifold collector = B2S1 (plugs 2-4-6-8)
    Right (rear) bank exhaust manifold top = B1S1 (plugs 1-3-5-7)
    After-cat passenger side of pipe = B1S2
    In the earlier models there is also a pre-cat sensor, so the right bank/exhaust numbering is B1S1, B1S2, B1S3.
    If you really want to see what YOUR engine is doing in any 4 of 12 gauges at a time, take a look at a ScanGauge-II. The unit can also be programmed by you to show an additional 4 gauges, depending on just what your engine monitors (GM service manual info). The unit is also a code scanner and secondary fuel mileage computer. Two units may be daisy-chained and will display 8 gauges at one time. I use one and normally monitor intake air temp, coolant temp, ignition timing and MAP (inverse vacuum). www.scangauge.com
    68
    82,081
    Using the HVAC should have no affect on engine temperature. It should stay at 12:00. Might want to check your purge line.
    Jul 2011
    5
    Checked the purge line, good flow, anti. nice and clean.
    Car just turned 37000, all required maintance at milage intrevals has been performed. Never aboused!
    Its so strange that the po135 popped up along with the temperature rise.
    The fan kicks on at 226, temp rises alittle and then falls back down to just above 12 oclock, never used to move needle at all.
    I wonder if maybe some other component might be triggering the 135?
    As per reply form submariner 409, the sensor that I need to replace is on the left bank, before the converter? Only one sensor on the left bank?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Your code is specifically for the heating circuit in the O2 sensor. Nothing else can cause the code.
    Your temps are fine, and the fans are coming on when they should be (low speed ~224, high speed ~236). If you believe the engine is running hotter than it used to, check for dirt/leaves/debris buildup on the condenser, and check the condition of the water pump belt and tensioner.
    68
    82,081
    One O2 sensor on each manifold and one after the CAT. Bank 1 is the right (firewall side) bank. Banks 2 is the left (radiator side) bank.
    Feb 2006
    56,267
    Quote Originally Posted by ELDO 02 #1496 ETC View Post
    As per reply from submariner 409, the sensor that I need to replace is on the left bank, before the converter? Only one sensor on the left bank?
    Post #6. Bank 1 is the right bank, cylinders 1-3-5-7, the bank closest to your feet, P 0135, heater circuit performance, Bank 1 Sensor 1.
  14. Remove Advertisements
