1998 Seville - Air blend door problems
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1998 Seville - Air blend door problems in Past Cadillac Vehicle Discussion; What does anyone suggest I do to fix my a/c problem? It only blows out cold on the passenger side ...
    Dastro79's Avatar
    Dastro79 is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac Seville STS
    May 2012
    Chicago, IL.
    37
    44
    What does anyone suggest I do to fix my a/c problem? It only blows out cold on the passenger side & hot on driver side...? The rear vents work also. Heat works fine on both sides. Can simply recharging the a/c solve this issue? That's what someone told me to do. It does maybe need recharging because it doesn't get as cold as I think it should.
    Dastro79's Avatar
    May 2012
    Chicago, IL.
    37
    44
    Re: 1998 caddy STS fixed wp pulleys & belt. More issues!!!
    Codes are B1340(air mix door one movement fault) & B1343(air inlet door movement fault) How do I fix this?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,133
    Get down to Cadillac Tech Tips and find the threads (many pages) on how to remove the glove box and passenger side kick panels to get to the HVAC blend door actuators.
    Google something like "cadillac forums 1998 seville air blend door actuator" or "cadillac forums 1998 seville hvac blend door motor".
    ............ and "charging the A/C" on one of these critters is more than just hooking up an el-cheapo can of R134a. It's properly done by total refrigerant weight from scratch.
    89falcon is offline Cadillac Owners Fanatic
    Automobile(s): my wife crazy, 1997 STS, 2004 CTS
    Apr 2011
    188
    Quote Originally Posted by Dastro79 View Post
    check for a vacuum leak.....
    Dastro79's Avatar
    May 2012
    Chicago, IL.
    37
    44
    ok. Well I guess there are gonna be some things I'm just gonna have to pay professionals to do. (Dammit)! lol
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Forever West
    26
    5,770
    Not necessarily. ANYTHING can be done on a car by the layman, you run into problems with time, tools, and space.
    Feb 2006
    57,133
    Quote Originally Posted by 89falcon View Post
    No vacuum involved - HVAC console and sensor-controlled stepper motors on the blend door shafts. (Hmmmmm........... 1998 - the parking brake release is vacuum.................. or did the '98 go to the solenoid ?)
    Dastro79, I started a new thread up in Seville concerning your air blend door problems. You'll get more advice up there than you will in 'Engines". "1998 Seville - Air blend door problems"
  10. Remove Advertisements
