clearing code for air conditioning
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, clearing code for air conditioning in Past Cadillac Vehicle Discussion; does anyone know the procedure for clearing code so air conditioner compressor will come back on, in a 97 seville ...
    skinsatrfk is offline Cadillac Owners Member
    Automobile(s): 1993 seville and 1997 seville sls
    Sep 2012
    1
    does anyone know the procedure for clearing code so air conditioner compressor will come back on, in a 97 seville sls? changed compressor and now wont take a charge. still says compressor off.
    barrylee is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Seville SLS
    Feb 2012
    Bentonville, AR
    87
    on mine i unhooked the battery to get to reset so the ac would kick in and take a charge. dont know if thats the preferred method though.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: clearing code for air conditioning
    Battery won't do anything it will NOT reset the codes.
    You need to go into the vehicle diagnose mode, navigate to ACM and then select "clear codes".
    That's about it.
    69
    82,377
    See the DTC sticky at the top of the forum page. It will have the procedure.
    Feb 2012
    Bentonville, AR
    87
    wont clear codes but will reset that emergency cutoff for the compressor long enough to get some 134 in there
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,845
    Quote Originally Posted by barrylee View Post
    no such thing as an emergency cutoff in the AC system -
    but the low pressure switch would prevent the compressor from engaging -
    Feb 2012
    Bentonville, AR
    87
    my car said low refrig turning off compressor on the DIC. wouldnt engage wouldnt takeva charge. whatever you call it the compressor wouldnt turn and wouldnt take a charge until i unhooked the battery.
  10. Remove Advertisements
