Results 1 to 11 of 11
Thread: Scary ride - 2001 SLS broken steering rack mount
    butch h is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2007
    28
    Wife and I were coming down a long hill,with a sweeping left-hand curve,when it felt like we were Ice Road Truckers.Instead of a slight steering wheel movement,I suddenly had to turn the wheel a quarter turn or so.At 55 mph this will get your attention.Short story got car on a lift('01 SLS) ,and found the steering rack had a broken attachment on the passenger side.
    Has anyone had this situation? If so,what was repair like?I replaced the rack assembly on our '87 Seville without dropping the engine cradle,but this doesn't look likely here.
    Thanks ,Butch
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Scary ride - 2001 SLS broken steering rack mount
    Is not the first time I hear about a broken mount on the rack (various years).
    The cradle is NOT needed to be dropped for such a repair.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    I had the broken steering rack mount on the passenger side. It would trigger stability systems and I couldn't turn accurately.
    The rear side cradle had to be lowered just enough to gain access to the steering rack. It doesn't have to be removed.
  5. #4
    Mar 2007
    28
    O K,what is the repair procedure? Does the rack have to be replaced?
  6. #5
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Yes!
  7. #6
    Mar 2007
    28
    Well I went ahead and dropped the sway bar links(they will need replacement),removed the heat shield,moved everything that was likely to be damaged,and removed the broken piece of the rack.After looking things over,I brought in my main go-to guy and had the part welded back on.It looked as if it had been broken on one side for awhile.After restoring all that I had removed,or moved all is good.
  8. #7
    fritcr is offline Cadillac Owners Member
    Automobile(s): 2003 Cadilliac STS
    Jul 2012
    49
    44
    Can I ask what kind of signs this thing was exibiting before it came loose all the way?
    My 03 STS makes a lot of clunking sounds when turning or going on the gravel. On the hwy it seems to "be hard to turn" as my wife puts it. If you have a slight curve in the road it is hard to make the car start to turn a little if that makes any sense. It is like one wheels turns just a fraction before the other one. It is a very strange feeling and I just had a dealer align it and road force balance the tires. I think it drives worse now then before they worked on it. It has a bad shake..(tire slightly out of round) they said.
  9. #8
    Mar 2007
    28
    After repairing the mount,we noticed a much improved directional stability.Before the total separation of the mount,it seemed to require a lot of steering correction.
  10. #9
    Jul 2012
    49
    44
    That is exactly what mine does now! It it like it is "squirly" in the road. ie...can't stay in your lane easily.
    How exactly can I check to see if mine is starting to break/crack or whatever. What do I look for?
    Thanks so much for your replies!
    Rob
  11. #10
    PineyJustice is offline Cadillac Owners Fanatic
    Automobile(s): 2001 deville base, 2008 dts
    Apr 2012
    Michigan
    27
    310
    One of my rack bolts fell out in the driveway when I was backing out!
    I noticed something was wrong with the steering, turned the wheel back and forth a couple times and heard the ping of steel hitting concrete.
    Thankfully all I had to do was get it back in the right spot and torque both of them down (the other one was loose enough to let it jump out of the U notch)
  12. #11
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Visually looking at it would be the only good and final answer.
  • You may not post replies
