Running 18" wheels on 95 Eldorado, pressure question
Results 1 to 15 of 15
Like Tree2Likes
  • 4 Post By RippyPartsDept
Cadillac Seville / Cadillac Eldorado Forum Discussion, Running 18" wheels on 95 Eldorado, pressure question in Past Cadillac Vehicle Discussion; Put some 18's on my Eldorado, tire size 245/45/18. It had the stock 16's before. Ride seems a little different, ...
    eldoradogary is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Eldorado, 2000 STS
    Jun 2012
    61
    134
    Put some 18's on my Eldorado, tire size 245/45/18. It had the stock 16's before. Ride seems a little different, not quite as smooth. Anyone else running these size rims and tires? What air pressure have you found gives the best ride? 35 psi in all 4 now.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Re: Running 18" wheels on 95 Eldorado, pressure question
    30 - 32 psi, cold. Always check/adjust tire pressures cold, never warm/hot.
    Jun 2012
    61
    134
    Thanks, I'll give that a try.
    Feb 2006
    56,827
    Something to remember about "ride" when changing to larger diameter wheels (from stock size): Your original tire outside diameter was about 27", so with 16" wheels you had about 5.5" of air/rubber between the wheel and pavement. Now, with 18" wheels you have reduced that "cushion" to 4.5". The car will ride "harder". (16" wheel, 27" OD tire = 11" of "tire". 11 / 2 = 5.5") (18" wheel, 27" OD tire = 9" of "tire". 9 / 2 = 4.5" cushion)
    Your new tires are the exact correct size for the car: If you change tire outside diameter by more than 0.25" you run into speedo calibration and powertrain management (shift point vs. power) problems.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    you can use a tech2 to tell the car what size tires you are using so it calculates speed, mpg, etc correctly
    well i know you can do it for a '97 at least
    Jun 2012
    61
    134
    Quote Originally Posted by Submariner409 View Post
    Thank you, yes that's what I figured less rubber betweeen wheel and pavement equals a little harder ride, still not bad though and worth it as it looks incredible.
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    pictures please.......
    Feb 2006
    56,827
    Quote Originally Posted by eldoradogary View Post
    I'm seriously considering going to the Deville chrome spoke 18's with Z tires - for the lower sidewall handling aspect of tire/wheel sizing. My car is a F55, so there's no such thing as a "Cadillac ride" there, anyway.
    Feb 2006
    56,827
    Quote Originally Posted by 98eldo32v View Post
    Somewhere near here is a thread with a picture of a Seville with Deville 18's on it. Looks great - just cover up the rear door.
    About 20 threads from here - 02 STS - 18" rims ? - All you gotta do is look outside the box ..................
    Jun 2012
    61
    134
    Not the greatest pics, but you get the idea.
    Jun 2012
    61
    134
    badmofo.pngHere's a better picture but I can't figure out how to post a bigger one.
    98eldo32v's Avatar
    Apr 2010
    51
    2,125
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    Hard to find colour, one of my favorties, does it have the matching purpleish interior?
  16. #14
    Jun 2012
    61
    134
    Quote Originally Posted by STS_Seville_Hunter View Post
    Yes, it has the matching purpleish leather. I've never seen another in this color, mocha pearl, almost looks lavender in certain light.
  17. #15
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Pressure is one thing but brand/speed rating is another. Pretty sure most 45 series tires are max performance. The sidewall construction is a big variable.
  18. Remove Advertisements
