95 Eldorado coolant temps
Results 1 to 9 of 9
Like Tree1Likes
  • 2 Post By Ranger
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 Eldorado coolant temps in Past Cadillac Vehicle Discussion; what's too high a temp & if the car is idling should the temp rise...
    topnotch is offline Cadillac Owners Member
    Automobile(s): 95 eldorado 73 calias
    Nov 2011
    houston
    17
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,263
    Re: 95 eldarodo coolant temps
    The thermostat starts at 188 and is fully open at 206. The car should run between 195 - 205 on the road. With no A/C function set the fans are controlled by the ECT and will go to Slow at 224 or Fast at 236. With some A/C function set, fans run in Slow all the time.
    So, with no A/C a temp rise at idle is perfectly normal. With A/C, temp should hang around 195 - 210 (in heavy traffic).
    Too high ???? 240. Overheat - 265
    wlewis is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado
    May 2011
    31
    Re: 95 Eldorado coolant temps
    The temp gauge on mine stays almost straight up, maybe one width of the needle past 12 oclock. Once it is up to temp it pretty much stays there if I'm stopped or 70 MPH on the interstate. I just recently activated the coolant temp to be visable via the DIC. There's a thread on how to do it in the tech tips section. I've had the head gaskets repaired on mine so I find myself constantly checking the gauage.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Don't worry about it unless it goes way over the middle. Keep your DIC at somewhere else other than coolant temp so you don't have to worry about it the whole time you drive the car.
    Nov 2011
    houston
    17
    it's in between 219& 245 & i loseing coolant but without a leak i had the radiator replaced but i think they used the wrong one because there's a xtra port on the passenger side that doesn't have anything connected to it
    68
    82,081
    The port on the passengers side is for an oil cooler, which you obviously do not have. That's not a problem or the wrong radiator.
    245 is too high. If you are running hot, loosing coolant and have no external leaks, it's time for a block test kit.
    maeng9981 and maeng9981 like this.
    Nov 2011
    houston
    17
    no not running hot once i start moving the temps come down but mostly stays around 223 to 235
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Losing coolant and high temperatures do not sound good. Have it block tested. But....if the temperature is going up only when you stop, you might have issues with the cooling fans.
    Nov 2011
    houston
    17
    yes when im driving there around 223 but if i stop and get out & leave it running in the day time, when i get back in it there around 240 sometimes 250 i live in Houston so it gets pretty hot in the day time & thanks for all the feed back
  12. Remove Advertisements
