1999 STS | Traction control module/Rearview mirror???
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By N*Caddy
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1999 STS | Traction control module/Rearview mirror??? in Past Cadillac Vehicle Discussion; One last electrical gremlin. Dothe tranction control module and the rearview mirror compass share a common ground? They constantly short ...
    Ryan Wall is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac STS
    Mar 2012
    39
    58
    Dothe tranction control module and the rearview mirror compass share a common ground? They constantly short out and power back on at the same time. Almost always when i start the vehicle they "lag" by about 30 seconds and they also cycle on and off while i am driving.
    Thanks for any ideas.
    Mar 2012
    39
    58
    Re: 1999 STS | Traction control module/Rearview mirror???
    Here are my codes:
    ( I am including History codes as the problem is intermittent )
    b1805 |History| - Ignition Switch Problem
    B2221 |History| - Left Front Door Lock/Unlock Switch Stuck UnLock
    B2242 |History| - Memory Exit Switch Failed
    b2243 |History| - Memory Set Switch Failed
    U1016 |History| - Loss of Class 2 Communication with VCM
    U1170 |Current| - Loss of Driver Door Switch Asm Serial Data
    U1040 |History| - Loss of Class 2 Communications with ABS
    U1064 |History| - Loss of Communications with DIM
    U1255 |History| - Class 2 Communication Malfunction (Serial Data Line Malfunction)
    P1602 |History| - Knock Sensor (KS) Module Performance
    C1736 |Current| - Compressor Relay Short to GND/Open Circuit (Intentional)
    C1761 |Current| - Right Front Position Sensor Input Fault
    C1780 |History| - Loss of Steering Position Signal
    C1783 |History| - ICCS2 DL Left Output Short Circuit to GND
    C1785 |History| - ICCS2 DL Right Output Short Circuit to GND
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    there's your problem!
    All those U codes are probably related with this, looks like in the same way the mirror does not get power on time so do the other modules (stuff you don't see).
    This will cost you about $500 (new ELC compressor)
    Remove your front left wheel and inspect if that small rod is attached between the lower control arm and the height sensor. Worst case scenario (assuming the wiring is fine too) you need a ~$200 height sensor.
    Very common issue with gen V cars, especially around '99 production year. Is a $80 steering position sensor at the base of the steering column. Can be changed relatively easy, post on how to do it available on this forum.
    This is the 2 ICCSII Data Lines between EBTCM and CVRSS (communicates the road surface texture from CVRSS to EBTCM to control the aggressively of the ABS action when required). These lines replace the need of having the snow, sand, gravel and rain selection button like in other (simpler) cars.
    Is either the EBTCM or the CVRSS shorting the lines to ground or you have a harness issue.
    Mar 2012
    39
    58
    Thanks a lot n*caddy. Nice to know what direction to travel in!
    The c1736 code is there because i have removed the relay so my compressor won't run. I did this a a short term solution as the bladders on the rear air are both shot (leaking badly).
    I will start by searching for solutions to the b1805 code.
    Where is the ground specific to the Ebtcm & cvrss?
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Is not common, CVRSS is in the trunk, EBTCM is behind the radiator - driver's side.
    Ryan Wall and Ryan Wall like this.
  8. Remove Advertisements
