Possible transmission trouble - Page 8
Page 8 of 10 FirstFirst 12345678910 LastLast
Results 106 to 120 of 146
Like Tree6Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Possible transmission trouble in Past Cadillac Vehicle Discussion; OOPS, sorry, the previous post was done by me. Actually GeorgeJung visited me over the weekend and logged in on ...
  1. #106
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Possible transmission trouble
    Actually GeorgeJung visited me over the weekend and logged in on the forum using one of my Laptops.
    I didn't check if it was logged off and just went ahead and replied to my thread.
    Sorry it was an issue of mistaken identity.
    I guess I got you all confused.
  2. #107
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    the only difference that you can see in the parts catalog are those RPO codes
    i think they had to do with leaded gas or something ...
  3. #108
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    I was literally dialing your number today when I got a message from Jake that he found it with GM locally.
  5. #109
    Sep 2007
    Wilmington, NC
    13,969
    yeah no worries... i'm sure it will work out better/easier (and maybe even cheaper) through Jake
  6. #110
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    ...it's not the leaded gas... ...my old MAE export 1997 Seville STS got also the NN8 code...(and we use unleaded fuel...there is no leaded fuel in Germany... )
    ...the Cadillac dealer RPO print out says for NN8: emission override code, emission system, unleaded fuel (export)
    (...whatever this might have to do with the transmission...)
    ...btw....it's only an (or one) assumption...but...
    Quote Originally Posted by N*Caddy View Post
    Just curios, what would be the difference between export and domestic transmissions?
    ( OOPS, sorry, the previous post was done by me.)
    ...does the "domestic" marketed STS also change/shift to the "4th gear" at full throttle/with fully depressed gas pedal/WOT (e.g. a run from start/"0" to maximum speed)...and does it stay in 4th gear at "autobahn"(high-) speeds (full throttle) ...like the (european Z-rated) export ones?
  7. #111
    Sep 2007
    Wilmington, NC
    13,969
    Yeah you're right ... I would also assume that there's something slightly different but wouldn't that gearshift change be software and in the PCM not a physical hardware difference?
  8. #112
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    I know that the domestic firmware does downshift on cruse control when going on a very steep uphill and it can do almost a WOT (I found out crossing the mountains in Colorado). Say you have the cruise control set to 70MPH driving on a rather flat stretch of road and all of a sudden the road goes up in a 10% slope, the car will loose speed, you can see the cruise control giving more gas, up to the moment when the PCM decides it needs to downshift as is not enough, and that’s when the RPM goes into 5500 RPM. Obviously will speed up pretty fast at this point when will up-shift and again start loosing speed and the cycle repeats (about 2-3 times per mile). There are some very long slopes in Colorado so it does this allot. You can play with it accelerating with the cruise control buttons and it does the same downshift. It seem it has a specific acceleration rate set while on cruise control, that works fine on flat ground but requires downshifting uphil.
    Also the highest speed I have seen the car in 3-rd gear was ~120MPH, that's when it shifted in 4-th (it was at WOT) and then it stayed in 4-th all the way to fuel cut out.
    That was with the original transmission, with this one I have now (for another week or so) I never passed 140MPH. It did seem a bit rough shifting (especially 2-3 sometimes like you get rear-ended) and strangely the 3-4 shift was smoother than the original. However it kind of felt like I lost some power, it was not as eager as before. It also felt it needed more RPMs to leave from stand still (like the TC would be higher stall), I don't remember doing 2000 RPM when leaving from a traffic light in normal traffic. Basically no matter what speed I was in (or how fast below 60MPH I was going) the engine was 95% at 2000 RPM.
    BTW, last time I saw leaded gasoline in Europe was in the very early 90's.
  9. #113
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    5500rpm? 70mph is 2500rpm in 4th. It's 3500rpm in 3rd? Or 4500rpm in 2nd? Someone will toss in rpm tables soon
  10. #114
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    You have to account for the TC slip, we are talking accelerating not cruising.
  11. #115
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Jake text me today the new transmission is at the dealer in Ontario.
    Pending for him to schedule the car in for next week.
    I decided to stud the engine (for no reason) since it will be the 3-rd time is pulled out of the car in 6 months (and it was sitting there for over 16).
    All required fluids are ready (like always)…come to think of I will need 1 extra jug of DexCool.
    2008 was my peak year in car expenses (not including gas/oil/insurance) at just shy of $15K, this year I have a very good chance to blew past that.
  12. #116
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    ^ $15K/year maintenance? I don't and never will understand that. I would let the car ghostride down the highway first.
  13. #117
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Today the tranny started making (occasionally) the same whine noise as the original one when shifting in 2-nd (and again only when cold). What are the chances!?!
    Also I believe it slips in 3-rd, I mean is either bad misfires (and it should not as plugs are ~20K if so and I have no codes) or is actually slipping.
    Then I know I have what use to be transmission fluid, now is crud in the tranny so that may have a contribution.
  14. #118
    Cadillac Jane is offline Cadillac Owners Member
    Automobile(s): 1995 Seville SLS/155,000
    Nov 2010
    SC
    35
    Could it be a defective PCM?
  15. #119
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    No, we are talking of mechanical issue in the tranmission.
  16. #120
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    So your brand new tranny is making the same noise as the old and possibly slipping.what are the chances, bummer.
  17. Remove Advertisements
