Possible transmission trouble - Page 10
Page 10 of 10 FirstFirst 12345678910
Results 136 to 146 of 146
Like Tree6Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Possible transmission trouble in Past Cadillac Vehicle Discussion; You need a scooter or something small. I know you don't have space for a second vehicle at your place, ...
  1. #136
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    You need a scooter or something small. I know you don't have space for a second vehicle at your place, have you considered getting a second beater and parking at self storage place? I have paid people to park extra cars at their homes also. Just a thought N*.... Wish you luck getting it back soon.
  2. #137
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Re: Possible transmission trouble
    So it begins...
    This is the box with the BRAND NEW transmission
    Jake is now working on it, drilling the block, studs, gaskets, new transmission...he will be working over the night and tomorrow eve we are doing the first test drive. I will pull a very last rabbit from the hat to somehow get to work tomorrow (my boss became interested in the situation with my car, so hint, hint).
    We are rolling back the clock little by little to 16 years ago...next new spark plug wires, wheel hubs, brand new OEM replacement rims waiting...
  3. #138
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Damn thats just sexy. I wish i can get a new transmission.
  5. #139
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    And here are the (perfectly functional) gaskets @181K
    Jake is not happy with them, but in my books these are the best I have seen by far.
    Cylinders 2 (especially) and 4 look a bit lean, everything else looks dirty. Is true lately was driving more and more on city streets and less on HWY, but is a bit too dirty for my expectations. Always the best gas, always fresh oil, occasionally ran at WOT. Is true the spark plug wires are due for replacement, I noticed in the last month a miss or 2, and tested with the water mist was discharge galore, hence the reason I bought new ones.
    Jake was not happy with 2 of the bolts.
    I can't tell much from the pictures about the cylinder walls.
    eldorado_97 likes this.
  6. #140
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    And this is the today's progress:
    Nothing wrong before but this is better.
    Jake provided me with a picture of the cylinder walls, I can see the honings but I can see also something else:
    He said that scratch is not concerning, but I am a bit disappointed.
    Tomorrow is the pick up.
  7. #141
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    lookin' good!
  8. #142
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    She is finally back in my garage since last night.
    The drive home last night didn't went without adventures, the slider on the rear left wheel brake caliper seized after siting for so long. The grease got thick and hard inside the rubber boot plus the ear hole with the rubber sleeve got rusted and tightened the rubber around the slider. These combined translate in when applying brakes the inner pad was remaining pushed against the caliper. After about 5 miles when slowing down to a stop sign I heard a rub from the rear wheel. I pulled over and the rotor was glowing.
    Jake came to my rescue with a hammer that got the caliper unstuck up to first time I had to apply brake again.
    Eventually every time I was breaking I was pulling over and waking the caliper with the jack wrench, that pretty much destroyed the wrench and chipped the rim in few spots (I was hammering the caliper at night in between the spokes, few knocks got to the rim not the caliper).
    This was only annoying as I was about to replace the brakes anyway, and that rim was to be replaced as soon as I change the tires (unfortunately still good for a while).
    Funny fact once I got to the HWY I drove ~75 miles without applying brakes once .
    Today I spent most of the day working on the car. I fixed that caliper (for this week at least until I get the brake parts).
    The transmission was engaging softly into D, turned out to be the shifter cable (a bit too loose), so D was rotating the shifter shaft just partially into D. Now everything is perfect, the shifter knob is very sharp (the trick is to match the clicks of the shifter mechanism with the ones on the transmission shift shaft).
    I replaced the spark plug wires too, that really made a difference, is so smooth now, and then I installed plastic clips and redo some of the electrical tape on the engine bay harnesses.
    One comment about the spark plug wires, they got the lengths wrong, I still have the original wires and compared new wire against, 3 of the longest wires were the same length (not the case with the original ones), we are talking differences of 2 inches in some cases. Is a bit disappointing for a $150 wire set.
    I now have 100K warranty
  9. #143
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    PM R1 concepts for price quotes on brake components you'll get a super killer deal
  10. #144
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    It was always nice to get back into my Seville after not driving it for a few days (in your case months). There is something very special about these cars.
  11. #145
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Brakes I will get from a local AcDelco supplier I have an account with, I am looking for the rotors for my production year but the pads for '98+ with the slots for the brake wear sensor. I am planning to add the feature to my car. Unfortunately will involves some hardware changes to the IPC, cannot install it using the original set up as my IPC will not support the feature (even if I replace the EBTCM and CVRSS modules assuming the struts will be compatible). I will just make the IPC brake light turn ON when breaking if the sensors are gone.
    Now back to the subject:
    Obviously I am driving it paying attention to every single thing that seems to be out of the ordinary and I am happy to say so far it shifts fine, no jerking no noises. It did felt a bit funny once while shifting into 4-th doing ~70MPH, it seemed to me a bit sluggish (no jerk or anything just looked like it took a bit more time to shift than I would expect). I hope is nothing, I will keep an eye on it.
    Engine, didn't had an issue before so is not surprising is fine now, no leaks no funny noise all fluids to correct level.
    Did I mentioned Jake fired it up it at the first try once was put back together?
  12. #146
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,873
    Glad she's back on the road, Jake is a good mechanic and she was in good hands.
  13. Remove Advertisements
