95 STS - Twilight Switch and Window Switch not working
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 STS - Twilight Switch and Window Switch not working in Past Cadillac Vehicle Discussion; My twilight switch isn't working correctly, with it turned off (slide all the way to the left) , everything operates ...
    hybridamp is offline Cadillac Owners Member
    Automobile(s): 1995 Seville STS
    Dec 2011
    KY
    10
    My twilight switch isn't working correctly, with it turned off (slide all the way to the left) , everything operates fine, with it turned on (any position not absolute left) my headlights and interior dash lights dim in and out continously as if there is a short. The only trouble code relating to this that I have in history is:
    I022 - Panel Dimming Switch Pot Circuit
    The dimmer actually works perfectly with the twilight slider all the way off. Is this a true slider pot in which de-oxit may help improve the connection?
    Also, my driver's side rear window will not roll down, no codes about that of course. Motor or switch a common failure point on these vehicles?
    Thanks guys.
    68
    82,070
    Re: 95 STS - Twilight Switch and Window Switch not working
    Can't answer your dimmer question with any certainty, but I'd give Deoxit a try. Kind of sounds like that's where your problem lies.
    Does the rear window not work from both the drivers and the rear seat position? If it works from one, but not the other, then it has to be the switch. If not, then look beyond the switches.
