Results 1 to 5 of 5
Thread: Proper coolant service for 4.6L Northstar engine
    Realkonceptz is offline Cadillac Owners Member
    Automobile(s): 2000 SLS
    Aug 2012
    St. Augustine, FL
    35
    Hey fellow caddy heads, I was wondering if anyone knew what the proper coolant service consisted of for the Northstar engines. I don't want to end up with my heads separating from the block like others have in the past. What is the correct coolant to use as well?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,698
    Re: Proper coolant service for 4.6L Northstar engine
    Dex or green doesn't really matter - change it every 2 years
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    The heads will go because the bolts pull from the block, not because of coolant, some say its the coolant. If coolant was the cause then even studs or serts would still cause failure but they dont imo.
    With that said, get a coolant flush done, GM recommends 50/50 Dex-Cool. And change it religously every 2 years, dont neglect this.
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,864
    ....... and, for your 2000 SLS, while you're doing a coolant exchange, inspect the water pump drive belt and tensioner pulley: That tensioner pulley - given its age - can fail at any time and leave you stranded. The tensioner pulley/bearing can be had for $25 from RockAuto. Gates. Pictures in my albums.
  6. #5
    Aug 2012
    St. Augustine, FL
    35
    Thanks folks you've been a big help!
  • You may not post replies
