On my trunk deck,,there are four [4] lights two [2] per side,,,had a light out ,and went to replace it,,it was rusted really bad,,of course it broke ,and I had to use needle nose pliers to remove it,,the socket was damaged so I replaced it as well,,,after installing new connectors and bulb still will not work,,after checking the wiring with a tester ,,,no power to it,,,I have the original owners manual,,look for possible fuses but unable to locate it,,DOES ANYONE KNOW WHAT THOSE LIGHTS ARE,,And also its the only ones that have conventional push and turn to lock,,the bulbs have a round metal base with 2 contact points,,the ONLY ones like that,,,help please
