95 Eldo Etc EBTCM burned
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, 95 Eldo Etc EBTCM burned in Past Cadillac Vehicle Discussion; Hey guys, long story short....spilled coolant on the EBTCM and it fried. Everything burned, it's done. Took off the connector, ...
    seigal007 is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Eldorado Touring
    Oct 2011
    6
    Hey guys, long story short....spilled coolant on the EBTCM and it fried. Everything burned, it's done. Took off the connector, have code I032 current only, car seems to be running/driving fine.. Is this safe, what's the risk of not fixing this? After a little research it's pretty pricy to replace both the EBTC and connector.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    Re: 95 Eldo Etc EBTCM burned
    Having a not working EBTCM will cause the ABS/TC to not work when needed. ABS/TC light will be on. Some members experienced the meltdown and they ended up getting a used EBTCM and wiring harness from salvage yards.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    The EBTCM is pretty well sealed (I am discussing '96+ units). The worst coolant can do is get into the connectors and mess up the connections. A bit of cleaning will fix the issue.
    Oct 2011
    6
    I got a connector from a salvage yard and will look online for a used EBTCM. I'm assuming I can splice the connector? I saw some other posts mentioning that they also had to take it to the dealer after to get the computer to except the new one, or something along those lines.
  7. Remove Advertisements
