ABS, Service Stability Sys, Traction control lights
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, ABS, Service Stability Sys, Traction control lights in Past Cadillac Vehicle Discussion; After pausing at a traffic signal, I noticed a grunting sound coming from the front on takeoff, then the ABS, ...
    92WHTSTS's Avatar
    92WHTSTS is offline Cadillac Owners Fanatic
    Automobile(s): 99 Eldorado ETC
    Jan 2011
    283
    After pausing at a traffic signal, I noticed a grunting sound coming from the front on takeoff, then the ABS, traction control and service stability sys lights came on. This only happens when I take off from a standing start or when I turn the steering wheel a certain way. What is causing this? The car runs great, just the annoyance of the lights being on and the potential of damage if I continue to drive it has me concerned.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,850
    Re: ABS, Service Stability Sys, Traction control lights
    Quote Originally Posted by 92WHTSTS View Post
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    my money is on a bad wheel bearing/hub -
    92WHTSTS's Avatar
    Jan 2011
    283
    Ran the codes and the only one that is current is ACM B1347. All the other codes were history codes, so I'm assuming they aren't relavent now.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    THEY ARE VERY IMPORTANT!
    You don't have the issue all the time, only once in a while, after that the codes go back to history.
    My bet is on a wheel hub.
    Post all codes, I don't even care if H or C.
  7. Remove Advertisements
