Stumbling issues - 1994 Eldorado
Results 1 to 10 of 10
Like Tree1Likes
  • 2 Post By TheCapnIsIn
Cadillac Seville / Cadillac Eldorado Forum Discussion, Stumbling issues - 1994 Eldorado in Past Cadillac Vehicle Discussion; When going down the road at operating temperatures, while giving just a small amount of gas the engine seems to ...
    TheCapnIsIn is offline Cadillac Owners Member
    Automobile(s): 94 Cadillac Eldorado
    Jul 2012
    17
    When going down the road at operating temperatures, while giving just a small amount of gas the engine seems to stumble or missfire, and sometimes even will completely stall after you take your foot off the pedal. When I unplug the EGR valve it works fine, but when I plug it back in the troubles come back. Already tried replacing the EGR valve but it had no effect. Any suggestions? (Besides just leaving it unplugged)
    94 Caddy Eldorado Touring, Northstar 4.6L
    wolfmansnake and wolfmansnake like this.
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    Try to clean the egr valve first.pull your codes and post with definition.there is a thread on here with steps and pics for cleaning the egr valve.
    Jul 2012
    17
    Re: Stumbling issues
    i already installed a new EGR valve on there. Still need to clean it?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,118
    Any trouble codes associated with either the EGR valve itself or the circuitry ? It sounds like the valve is being commanded full open too early in the throttle position sensor cycle - thus "leaning out" the engine, causing a stumble............. Plugged up EGR passages would not cause a stumble - part-throttle spark ping, maybe - but not a stumble.
    Jul 2012
    17
    only code i get with everything plugged in the way its supposed to be is P080 (throttle pos/idle relearn process not learned) cant get the code to go away most likely because of whatever issue is causing the EGR issues. I replaced the PCM, ECM, coils, spark plug wires, and spark plugs within the past month as well. When i unplug it i get the codes you'd assume would pop up with it unplugged
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    My bad I didn't see that you already changed it
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Look up how to do do the tps relearn not sure for your year but mine I had to turn key on for one minute then off for 15 seconds.
    Jul 2012
    17
    when i replaced the computer it came with a relearn process. ive done it numerous times already. still stuck with the same code, and it still stumbles.
    Red STS's Avatar
    Red STS is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Jun 2012
    54
    73
    Similar stumbling thread here.
    http://www.cadillacforums.com/forums...-low-idle.html
    Solved by replacing the ISC
    69
    82,372
    Re: Stumbling issues - 1994 Eldorado
    How old are the plugs and wires?
  13. Remove Advertisements
