replacing battery and alternator required for headlight & radio conversion?
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, replacing battery and alternator required for headlight & radio conversion? in Past Cadillac Vehicle Discussion; I converted my headlights to H4 (Xenon) bulbs. I also consider converting my radio to modern technology pulling & pushing ...
    70eldo's Avatar
    70eldo is offline Cadillac Owners Connoisseur
    Automobile(s): 1970 Eldorado.
    Sep 2005
    Dutchman in Germany
    41
    4,023
    I converted my headlights to H4 (Xenon) bulbs. I also consider converting my radio to modern technology pulling & pushing more power (200W).
    Would I need to replace my alternator and battery to something with more output?
    When yes, how much?
    ThnX!
    Red STS's Avatar
    Red STS is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Jun 2012
    54
    73
    Re: replacing battery and alternator required for headlight & radio conversion?
    200 watts ain't nothing to worry about. The car is old so..
    Remove and sand all connections, clean with dielectric spray before reconnecting to the: Battery, alt. starter and fuse panel.
    When you want to go to 1,000 W, there are some precautions to take.
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Quote Originally Posted by Red STS View Post
    Thanks!
    joseville is offline Cadillac Owners Member
    Automobile(s): 93 seville 4.9
    May 2011
    wisconsin
    32
    83
    red sts, what would those precautions be?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,925
    Larger (output) alternator/regulator assembly, parallel 12V batteries with isolation switch, larger high quality battery cables (both + and -) and high quality amplifier power 12V input cables. Upgraded body sound and vibration deadening materials. Dedicated tuned bandpass box woofer installation.
    txtaz is offline Cadillac Owners Fanatic
    Automobile(s): 72,92,02 Eldorado
    Jan 2013
    55
    185
    ^^^^ Hymm, Sounds familiar. You might want to read the audio and security forums.
    Some of us may have already done some (or all) of this.
    Taz
    70eldo's Avatar
    Sep 2005
    Dutchman in Germany
    41
    4,023
    Update: the connection to the high beams were switched, so inside the lighting cirquit the grounding was wrong on the high beams. This caused the lights to be very dimm.
    Also, I needed to replace the battery. Although the control light was lit it wasn't ok anymore.
    Head lights are ok, but not at full potential yet, so I will be looking for 80Amph alternator soon, especially when I swap for a modern (classic!) radio with higher output.
  10. Remove Advertisements
