Improved 03 Seville trunk seal??
Results 1 to 11 of 11
Cadillac Seville / Cadillac Eldorado Forum Discussion, Improved 03 Seville trunk seal?? in Past Cadillac Vehicle Discussion; Does anyone know what the difference is between the new improved GM trunk seal for 03 seville compared to the ...
    duns's Avatar
    duns is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Seville STS White Diamond F55, L37 w/Nav
    May 2009
    Wisconsin
    53
    174
    Does anyone know what the difference is between the new improved GM trunk seal for 03 seville compared to the old trunk seal?
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    Your trunk doesn't get filled with water.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,489
    Re: Improved 03 Seville trunk seal??
    Quote Originally Posted by Yaemish View Post
    my response was going to be "it doesn't leak" -
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Apparently, early in the life of my STS, it had a trunk leak. Now, I don't know what the "old" weatherstrip looked like, but several things were done to seal the leak: There is a re-design weatherstrip in the field - we know that. Also, it looks like liquid butyl rubber body sealant was used over the heads of any of the trim/weatherstrip screws at the top front corners of the trunk opening, and a rubber flap/strip was added that runs all the way across the area under the edge of the rear window glass. I also know that the retainer nuts/studs for the tail lamp assemblies were re-sealed - had non-hardening body sealer (monkey shit) placed around the assembly mounting studs before the nuts were replaced.
    I hand-wash the car pretty regularly, and have been through a few truly impressive thunderstorms lately: The trunk is dry.
    duns's Avatar
    May 2009
    Wisconsin
    53
    174
    Well... I just bought a new trunk seal because I happen to have a leaky one. I installed it and their is a blue dot on the seal that is in the middle visible. I gather this means the middle. But is the dot suppose to be up top by the window, or down below by the rear bumper??
    Feb 2006
    56,274
    The seal is already bonded into a one-piece unit or does it have ends - as in a long piece of weatherstrip ? The ends/seam goes at the bottom center - trunk latch area.
    ocgltd's Avatar
    ocgltd is offline Cadillac Owners Fanatic
    Automobile(s): 2001 STS
    Oct 2008
    London Ontario
    300
    How do you remove the plastic trim at the front of the trunk (below the window)? I seem to have a large piece of black plastic on my 2001 STS...wondering if my leak is there...
    SevilleKidd is offline Cadillac Owners Member
    Feb 2014
    1
    Where can one buy the improved seal for the Seville trunk as my 2000 Seville also leaks? I know I can probably buy one at a dealership but that will be overpriced
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    One of the biggest pains on these is that trunk leak but with the right seal and some black silicone I got mine sealed
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by SevilleKidd
    Get in touch with Chris at Rippy Cadillac (see the list of vendors at the top right of the page).
    Seamaster_007 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Cadillac STS (Diamond White on Medici Red, Z-rated)
    May 2012
    Winnipeg, Canada
    100
    I had a leak on my '97, turns out the black silicone that bonds the seal to the metal was dried out and allowing water the slip under the seal. Removed the whole seal, cleaned all the original silicone from the metal and seal itself, and re-applied the original seal with new silicone. Never had a single leak since.
  14. Remove Advertisements
