Vacuum & other things - 1996 Eldorado
Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Cadillac Seville / Cadillac Eldorado Forum Discussion, Vacuum & other things - 1996 Eldorado in Past Cadillac Vehicle Discussion; i also have air pulled through that valve (whistling noise) which causes the car to start hard, among other things. ...
    el_dorado_mex's Avatar
    el_dorado_mex is offline Cadillac Owners Fanatic
    Automobile(s): 1996 El Dorado and 1991 Cheyenne Pickup
    Jul 2012
    Puerto Escondido, Mexico
    38
    140
    i also have air pulled through that valve (whistling noise) which causes the car to start hard, among other things. and also it is slightly oily. but the reason i answer here is that there is a vacuum line connected (at least in my case) to that valve body, and pretty sure the hvac stuff goes there. although i'm not 100% sure, since the car came with vacuum lines connected wrong or disconnected , still looking for a good diagram to figure out where stuff goes... anyways, pretty sure that hvac goes to that port.
    68
    82,084
    Re: Whistling pressure relief on N* Intake Manifold???
    Maybe this will help. (3rd one from the bottom)
    http://www.autozone.com/autozone/rep...00c1528025ed69
    Jul 2012
    38
    140
    thanks for the link ranger, unfortunately that's the one that i also have on the hood and doesn't say a lot about the vacuum lines. i have two valves or switches that would like to have vacuum on them (driver side, near coils) and also the hvac stuff and reservoir, but i can't find any diagram that tells me where stuff goes. some former mechanic fooled around with that pretty nicely and now there is almost nothing connected (just booster and 2 sensors (one on the tb and one on the booster)). well, i now connected the hvac and reservoir to the port on the blow off valve and it works ok (except brake release). so you see, i'm pretty much starting from scratch regarding vacuum... also other stuff has been fooled around with, but that'd be offtopic... i guess i'll open up a new thread with pics and everything, should make things easier. thanks again!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,283
    The indicated diagram has the correct vacuum hose connections. The solenoid/switch/vacuum thingy next to the coils is the EVAP purge solenoid. It opens vacuum to the EVAP system at steady part-throttle speeds in order to purge the emissions charcoal canister. Somewhere over there is also the T which goes to the HVAC and parking brake control diaphragms.
    The port on the blow off valve ???? That's a constant air flow from the PCV system - the other vacuum lines are dead-ended: they move stuff in response to commands but they don't allow full-time air movement - as in: hisssssssss !!!!
    Jul 2012
    38
    140
    see, not much of the vacuum stuff is in the diagram, said so yourself...
    but i think you may help me with my doubts...
    i'll try to explain what i have in there: evap purge solenoid, one more alike right next to it (so which is which? and what does the other do?); the open port on the right side; the open hose coming from the charcoal canister (at least i hope so, maybe no canister); booster and sensors connected correctly; line going to hvac; line coming from reservoir; pcv valve and line and the line to compensate fuel pressure. just imagine that all this stuff is disconnected and some lines are missing, etc. as if you'd take over a semi finished engine exchange project, do i make my point? i'll post pics later today, your help is already greatly appreciated.
    Jul 2012
    38
    140
    didn't have a chance yet to take pics, tomorrow is very likely (was raining hard yesterday evening). but what i made quickly is a small drawing of what i have. please find it attached. if anybody out there would be willing to upload some pics or a small drawing of how you'd connect stuff, i'd appreciate it really much.2012-07-27 15.25.44_c.jpg
    Jul 2012
    38
    140
    vacuum & other things
    hi everybody,
    recently bought my first cadillac, a 1996 el dorado. like it so far, but knew in advance this is gonna be a project...
    this is actually the thread i opened after posting here:
    http://www.cadillacforums.com/forums...ml#post3038891
    first issue is vacuum related, here's 2 pics of two valves that i don't know exactly what they do, one is evap, but which???
    anybody got an idea?
    next thing i need help with is the rev gage, doesn't work and i'd like to know where the signal comes from, one of the shaft sensors? i'd like to go from the source, maybe something is disconnected...
    and the last one for today is the ignition system, starts hard, backfires sometimes and throws codes (actally it threw 27 today, related would be: ip1910, 1982, 2016, 2710 and 2750). changed out spark plugs today, and cylinders 3, 4 and 7 look as if they wouldn't fire well, now that's 3 different coils, hard to believe they screwed up all together. mostly it runs fine actually, seems only on acceleration that it takes some time to make the 8 cylinders work, i mean i just hold the pedal and after 2 seconds it starts to accelerate with more power.
    many other things to do with the car, ride control is screwed (don't know yet how much), cruise control doesn't work, ac compressor has a broken pin (that's actually the worst, like 500 bucks for a "new" one, just because of a pin...). changed the heater core today and reconnected it, that was actually pretty straight forward, liked it. just that by working on one of the tubes behind the engine i accidently disconnected a camshaft sensor and the vehicle speed sensor, no clue how i did that, but this is back to normal now...
    well, so if anybody has an idea on some of that stuff, any help is greatly appreciated! thanks for reading.
    Jul 2012
    38
    140
    took some pics today, but i think this is going too far in this thread. started a new one here:
    http://www.cadillacforums.com/forums...ml#post3041072
    Jul 2012
    38
    140
    double post...
    68
    82,084
    Re: vacuum & other things
    The top picture is the EVAP valve. Bottom one looks to be the same valve, but I noticed what appears to be a cracked vacuum lines.
    Not sure where the tach gets it's signal from. I would guess the CKP sensors.
    As for the hard starts and backfires, I'd start with plugs and wires (A/C Delco). Clean the TB and check for a leaky FPR.
    P.S.
    Codes are meaningless without their definitions.
    Feb 2006
    56,283
    el_dorado_mex, I moved your original vacuum posts to this thread to keep all the info on YOUR problem in one place.
    Jul 2012
    38
    140
    thanks for moving the posts submariner!
    thanks ranger for your answer, i'll change the cables, to rule out they are faulty. would it be common for the ignition module to have intermittent failure? i'd say that it might work or not work completely, but who knows...
    regarding the apparently cracked vacuum line, it isn't connected right now, that's just the "configuration" i bought it with. figured yesterday that with the engine hot the lower valve is triggering vacuum at idle, the other one didn't do anything till now. i guess i'll connect evap to the one that seems to be working and leave the other one alone till i find out what it does...
    the codes i threw just in to complete the topic, to be honest i yet haven't looked at them closely, i'll clean the memory and read out codes later on, to make sure the old stuff doesn't appear anymore. but as far as i could see in other posts regarding ignition problems, codes don't help a lot with that, since most likely you just get a general misfire...
    Jul 2012
    38
    140
    update: found the attached diagram (http://parts.nalleygmc.com), looks like both valves work in line to release fuel fumes to the intake. weird setup... so the only open port should be the connection to the incoming line from the canister. well, gonna set it up like that and see how that works.
    and yes, it's a quiet day at work
  16. #14
    68
    82,084
    That's the vent port. Your diagram looks correct. Hook it up like that. Line #2 is the PCV clean air (intake) line and line #3 is the PCV dirty air line (from the crankcase).
  17. #15
    Jul 2012
    38
    140
    thanks ranger, fortunately #2 and #3 are connected as supposed to, only the evap gave me a headache, but not anymore
    next thing i'll check later today (if the rain lets me) are the ckp's, i think they (or their connectors/lines) might be the cause of the ignition problem. any ideas on resistance out there? found different values, around 300 ohms from one source and 700 to 900 from another...
  18. Remove Advertisements
