Door Alignment
Results 1 to 5 of 5
Cadillac Seville / Cadillac Eldorado Forum Discussion, Door Alignment in Past Cadillac Vehicle Discussion; My driver door has loose hinges & I think the door is sagging a little bit. It just doesn't seem ...
    96 STS's Avatar
    96 STS is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Seville STS, 2002 Seville SLS
    Nov 2003
    Long Beach, MS
    49
    132
    Door Alignment
    My driver door has loose hinges & I think the door is sagging a little bit. It just doesn't seem to close as well as it should. Seems like it hits the striker too hard which makes me think that it's sagging just a little.
    I've looked very closely at the door/striker area while slowly closing the door, looking for any upward movement, but I don't really see any.
    The door does have play though when I lift up on it while it's half way open. Has anyone here adjusted their door's alignment? How hard is it to get proper alignment? I'd like to go ahead & do this until I can find some good used hinges w/o play. And then, of course, I'll have to do a complete alignment when replacing the hinges.
    Anyone have any tips on proper door alignment techniques?
    Any help would be appreciated.
    Cheers,
    96 STS
    an01sts is offline Cadillac Owners Fanatic
    Oct 2004
    MD
    59
    261
    Re: Door Alignment
    Hinge alignment has to to with the way the door rests against the body. If the door is aligned when it's closed, you don't want to dink with hinge alignment.
    Always use a step by step process before wading into anything: Of course you can verify that the bolts are tight, but before you start loosening things, first, determine where the slop comes from. From what you describe, it's probally in the fulcrum of the hinge. In the old days, you could replace bushings in many hinges, but I doubt it's that way on today's cars.
    If it's worn hinges, you'll have to align the door. As a starting point, use the old paint scars as a starting point for alignment, then adjust as necessary. The best way to explain alignment is that it's a hit or miss process.
    Oct 2004
    MD
    59
    261
    Re: Door Alignment
    I just noticed it when I hit the send button: Just to make sure that there isn't a breakdown in communication, the comment about aligning hinges refers to the fact that you are replacing the hinges.
    CaptainCaddy is offline Cadillac Owners Member
    Automobile(s): 1992 Fleetwood Broughm
    Jul 2009
    3
    Re: Door Alignment
    Does anyone have a procedure or write up for aligning Fleetwood Doors? I had to replace both passenger doors due it being sideswiped but catching hell aligning the front door. Its up as high as I can get it but still hits the striker about an 1/8 to 1/4 in too low. Any direction?
    thanks
    69
    82,287
    Re: Door Alignment
    Is the door out of alignment? If it seems straight and the gaps are equal, move the striker.
  8. Remove Advertisements
