2002 STS - aftermarket radio install not working correctly
Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Like Tree1Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2002 STS - aftermarket radio install not working correctly in Past Cadillac Vehicle Discussion; hi i just bought a cadillac seville sts 2002 about 3 month ago everthing electronic was working fine but i ...
    old_school is offline Cadillac Owners Member
    Automobile(s): CTS 2010 (2002 SLS R.I.P)
    Jul 2012
    SE Florida
    89
    Unhappy2002 STS - aftermarket radio install not working correctly
    hi i just bought a cadillac seville sts 2002 about 3 month ago everthing electronic was working fine but i just installed a new car radio and 2 12's sub and am haveing some problems with the dimming lights from the dashboard they work but i cant lower them down and the lights that should come out inside the car that lights up the air bottons and the power windows bottons not lighting up sometimes also the open door bell sounds scratchy and also seat memory not working sometimes too the one on the side of the driver door theses guys that installed the system did a very bad job dont know if this can be caues becaues of me not installing the pac need help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The stock HU is (was) part of the serial data bus, and anti theft system. You can install an after market unit, but you MUST use the correct adapter harness, a Metra GMOS-6.
    eldorado_97's Avatar
    eldorado_97 is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 STS, W/Nav
    Feb 2007
    Baldwin, Wisconsin
    27
    562
    Re: cadillac seville sts 2002 electronic not working ok
    ^Yep exactly as MC stated Gmos-6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,577
    YEP - there's yer problem -
    eldorado_97 and eldorado_97 like this.
    Jul 2012
    SE Florida
    89
    are you guys talking and the pac caues i never install the pac so the radio would work with the steering wheel controler i got the radio online from sonicelectronix.com and they dids send me the harness dont know if it was the Metra GMOS-6
    Jul 2012
    SE Florida
    89
    are you guys talking about the wire hamess to connect to aftermarket radio if so this is the one sonicelectronix sent me it was the scosche gm03b/gm03 or are you guys talking about the pac caues i never installed the pac so the radio could work with the steering wheel controler can this also caues problems
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes, the harness for the HU. The GM03/GM03B is the WRONG one.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,577
    2001 and newer Sevilles utilize a "data bus" -
    this connects virtually every electronic module throughout the entire car -
    if one particular module needs the information that is flowing through the bus -
    it takes that bit of information - if not -
    that bit of information continues along the bus -
    until it reaches the particular module waiting for that bit of information -
    when you pulled out the factory radio - you broke the link the data bus uses -
    Jul 2012
    SE Florida
    89
    ok thanks so how much is the Metra GMOS-6 cost and does this have anything to do with the pac for the steering wheel controler also the open door bell sounds scratchy can this be caues too y the the wrong wire hamess to connect to aftermarket radio or can it be a bad wireing or bad connection
    Sep 2010
    East Boston MA.
    29
    26,325
    The module you have for the steering wheel controls, and the module for the "dings", have nothing to do with the harness for the HU.
    Try Amazon for the GMOS-6, I'm sure it'd be cheaper than retail.
    Jul 2012
    SE Florida
    89
    ok thanks will check out Amazon so the pac for the steering wheel controls is something eles from the harness for the HU ok how about the open door bell sounds scratchy can this be caues too by the wrong wire hamess or a bad wireing or bad connection
    edit : i just talk to sonicelectronix they did tell me they sent me the wrong wire hamess it was not the GMOS-6 but when i want to hook up the system they did install a adapter harness but i think it was not the onstar the GMOS-6
    Jul 2012
    SE Florida
    89
    Re: 2002 STS - aftermarket radio install not working correctly
    so you guys think once i get the onstar the GMOS-6 the correct adapter harness in the car everthing should start working correct again
    Jul 2012
    SE Florida
    89
    what is the best adapter harness to get
    hi i was told to get the Metra GMOS-6 for my 2002 cadillac seville caues am haveing a little bit of problem with my electronic after removing the stock radio i am also haveing problem with the sounds sound fades and the warning chimes fades at time and its sounds scratchy i know i have the wrong adapter harness right now install but am seeing that others are haveing problems even with the Metra GMOS-6 which sould be the right one i was reading this here would this one be better to get the GMAH-32
    http://www.cadillacforums.com/forums...s-06-need.html
    Edit : i was also reading theses customer reviews at amazon and others too are haveing problems with the Metra GMOS-6 they seen not to be haveing problems with electronic like me with the wrong adapter harness but they are haveing problems with warning chimes fades which i am also haveing right now so am thinking the Metra GMOS-6 is just not going to work
    http://www.amazon.com/Axxess-GMOS-06...owViewpoints=1
  16. #14
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,577
    Re: what is the best adapter harness to get
    you should continue posting on your original thread
    rather than starting another new one with the same topic -
  17. #15
    Jul 2012
    SE Florida
    89
    yeah i know thought of that after post so do you guys know which would be the best adapter harness to get the GMOS-6 or the GMAH-32 for the GMOS-6 i was thinking of geting this one is this the correct one
    http://www.sonicelectronix.com/item_...s-GMOS-06.html
    which people seem to be having trouble with also would i still need to get the pac if i get this adapter harness GMOS-6 would my steering wheel control wrok again or would i need this pac here if its the right one
    http://www.sonicelectronix.com/item_...AC-SWI-RC.html
  18. Remove Advertisements
