Results 1 to 6 of 6
Thread: '77 Seville In-Tank Fuel Pump Module replacement (complete) -- or "Go Fish" ???
    MAD JAX is offline Cadillac Owners Member
    Automobile(s): '77 Seville (I like '67 - '75 Eldorados ; )
    Jul 2012
    At Large
    5
    I'm having a helluva time finding a COMPLETE In-Tank Fuel Pump Module that includes the Fuel Level Sensor, etc. so I joined this forum to find some help...
    I'm helping an old friend get his '77 Seville up 'n running that's been down nearly a decade, and have removed the tank for cleaning and sealing while I clean and replaced the fuel system lines and source replacements of BOTH Fuel Pumps (In-Tank and "Frame Mounted") as both are seized-up.
    I'm hoping I don't have to try salvaging the Level Sensor Module that was in there, as it's pretty well corroded with rust, etc., for the presence of contaminated/stale fuel...the Fuel Level Sensor is apparently shorted to ground for indicating a perpetually "Full" tank.
    Anyone know of a source for either N.O.S. parts or viable replacement parts?
    Otherwise, the system operating pressure is 39 psi....surely there's a replacement pump available from another application that'd install directly and work at or about that pressure, or what do You know?
    I've tried searching the forum to no-avail, but if there's a link or thread I've missed you know of please reply, your considerations would be greatly appreciated, thank you!
    Jack Gleason Mobile Automotive Diagnosis aka "MAD JAX"
    "Impossible" is a degree of difficulty...set by imagination for lack of motivation.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Re: '77 Seville In-Tank Fuel Pump Module replacement (complete) -- or "Go Fish" ???
    Talk to Chris in parts at Rippy Cadillac over there >>> or up ^^^ in Vendors
    Same for Luke at Lindsay Cadillac >>> or ^^^
    Look at the pics by clicking on the icons in www.rockauto.com (if they have '77 parts)
    Jul 2012
    At Large
    5
    MAD JAX & "Creating Jobs" ; )
    Thanks for the leads, but both dealerships referred me elsewhere -- essentially saying "Go-Fish" -- to places leading where I already was...Improvise, Adapt, and Overcome unless you can find what you need "Used" for a reasonable price...and the latter sure isn't happening!
    An In-Tank Pump Module using a similar analog sender that produces 37 - 44 psi. (with 3/8" Send, 5/16" Return, and 1/4" Vapor lines) that has what appears to be a standard Fuel Tank Sender opening, and -- even if I had to shorten or lengthen the lines and wiring -- it would work, one could eliminate the frame-rail pump altogether, and -- especially if that PN's application was really popular -- someone could probably make a mint selling them as replacements!
    We could collaborate on this, market it from this websites "Classifieds", and contribute 15% of all sales-profits to the site...I'll provide the "Guinea Pig" for R&D, So, Who's "In" : ?
  5. #4
    Jul 2012
    At Large
    5
    Re: MAD JAX & "Creating Jobs" ; )
    I've got the Tank being douched 'n sealed, rebuilt the Frame Mounted Pump (and verified it's Operation), and aquired the In-Tank Pump "Sending Unit Module" from a '82 Seville to which I'll be mounting "Todays Exchange Application" of a '77 Seville In-Tank Fuel Pump...based on what diagnosis has been performed so-far, if the Injectors aren't clogged-up and the Fuel Pressure Regulator functions correctly it should start 'n run once I get it all back together.
    Identify, define, improvise, adapt, overcome...I guess we'll see here quick!
    WTF...just got a msg. from the Radiator Shop douchin' the Tank saying "Call me ASAP"...NOW what's up : ?
  6. #5
    Jul 2012
    At Large
    5
    Well it's been quite awhile since that job was completed ~ Just for Grins:
    After getting the Tank douched 'n sealed, the Frame-Rail Pump Rebuilt, an '82 Seville "Complete in-tank pump-module" (with some minor modification(s) installed, ALL the injectors rebuilt, the pressure-regulator replaced, and the entire fuel-system back-flushed-clean ~ that Caddy fired-up and ran great!
  7. #6
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Better late than never! thanks!
  • You may not post replies
