1992 Eldorado Touring Coupe
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1992 Eldorado Touring Coupe in Past Cadillac Vehicle Discussion; While cleaning the throttle valve and trying to get the E085 code off my system the engine went to a ...
    Mharding is offline Cadillac Owners Member
    Automobile(s): 91 Sedan, 85 Brougham de 'Elegance (59k), 94 Seville
    Sep 2003
    Sarasota, FL
    29
    While cleaning the throttle valve and trying to get the E085 code off my system the engine went to a high idle and something made a loud popping noise... I suspect motor mounts since the engine rocked upward from the front. I can find nothing on mounts for a '92 ETC with a 4.9
    Car also stays at a set speed while going down the road without even using cruise control. When I brake it doesn't downshift till just before a complete stop.
    Any ideas?????
    Sep 2003
    Sarasota, FL
    29
    popping noise? motor mount
    I should have posted the problem in the subject line...Sorry
    kcnewell is offline Cadillac Owners Connoisseur
    Jan 2003
    Nevada, Still the land of the free!
    2,235
    Re: popping noise? motor mount
    It sounds like you have a bad occaisional misfire at high idle. I've seen this before during emissions testing. It usually means you need a tuneup. Do a complete tuneup and it'll probably go away.
