P0340 - Camshaft Position (CMP) Sensor Circuit
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Cadillac Seville / Cadillac Eldorado Forum Discussion, P0340 - Camshaft Position (CMP) Sensor Circuit in Past Cadillac Vehicle Discussion; Oh joy, a new code and new problem! LOL, just had my power steering pressure hose replaced on Monday and ...
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    Oh joy, a new code and new problem! LOL, just had my power steering pressure hose replaced on Monday and now this. Started yesterday, I've had a hesitation when just warming up but it would go away after I hit the gas pedal twice, but yesterday my car was barely moving and this lasted a few minutes, about 5 times hitting the pedal from a stop. Once about halfway warmed up the car is perfectly fine, no loss of power at all and idle feels normal.
    Also, after car was sitting for about a couple of hours last night and was about halfway warm and turned on I hit the rear defrost and the RPMs bounced up and down from about 500-1000 then settled after about 5x of doing it.
    What am I looking at as far as repairs go? Something I should get done soon?
    69
    82,380
    Re: P0340 - Camshaft Position (CMP) Sensor Circuit
    Not a bad job. Part #236 (rear head, passengers side). Cost should be in the neighborhood of $50.
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    Very easy to replace.takes about five minutes.
    Jul 2009
    29
    968
    That's great to hear. Just need to get home from work tonight and will take care of this tomorrow before work. Sucks hitting the gas and the car barely moves! Why does it run perfectly fine when warmed up?
    69
    82,380
    BTSOM!
    Jul 2009
    29
    968
    hahaha well I guess with 180k on the clock I should expect more things to start failing
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,126
    Ummmm...............If you had the P/S pump replaced, that's next to, and the hoses also, the CMP and its harness. Have you looked to see if it was unplugged for work room ?..........or if the wire(s) were yanked from the connector ?
    If the CMP is "not working" the ignition timing defaults to a static calculated 10 degrees BTDC - the engine will run but the car will feel unresponsive and sluggish.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Not a bad job?
    Very easy to replace? Takes about five minutes?
    I'm assuming you two guys have never actually changed one.
    Either that or you have 3 very small hands.
    The first challenge is seeing it.
    There's only a couple inches of clearance with 2 heater hoses in the way.
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I changed mine last year in like five minutes
    Feb 2012
    NYC
    50
    1,948
    I don't have my STS anymore. Is there more room to get to it in the STS than in the Eldo? Because it takes more than 5 minutes just to see it in the Eldo.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    No, not much room in the 5th gen Sevilles either. If you have big hands or arms, you'd better be able to hold small fasteners scissor grip style, with your index and middle fingers.
    Feb 2012
    NYC
    50
    1,948
    I gotta see the 5 minute thing for myself.
    Sep 2010
    East Boston MA.
    29
    26,323
    I replaced mine about a month ago, took less than 10.
  16. #14
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    On mine there wasn't anything in the way all though the person who had the car before me changed the power steering return line and re routed it another way cause he just used a plain ol rubber hose.(still need to change that)
  17. #15
    Jul 2009
    29
    968
    My mechanic said $100 for the part and $50 labor. Has to order it so he won't be able to get it done until Monday.
    Sub, I think it is beginning to fail. I would hit the gas and the car would barely want to move and that lasted a few minutes, about 5 times hitting the gas then it went away when car was just about halfway warmed up. Cleared the codes last night and as soon as I turned the car on the SES light came on, I let it warmed up for a few minutes and didn't really feel any performance issues when starting out. It is possible something might have got unplugged, I'll try to see if I can find it by looking at the pic above, but I didn't have the bogged down issue until Wednesday when I hopped in and let it warm up for like 10 secs then immediately started driving. Like I said too, I've had a slight hesitation issue for a few months now, assumed it was a vacuum leak but then that happened Wednesday and I have never had this code before.
  18. Remove Advertisements
