Air bag light on: CODE B0065
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac Seville / Cadillac Eldorado Forum Discussion, Air bag light on: CODE B0065 in Past Cadillac Vehicle Discussion; so ever since i got back from my deployment and hooked everything back up in my car this airbag light ...
    hylander6361's Avatar
    hylander6361 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Seville STS (106k miles body 77k motor, black)
    Sep 2011
    Minnesota
    24
    71
    so ever since i got back from my deployment and hooked everything back up in my car this airbag light has been on, i finally got around to getting it into my local shop and they said this code was the one that showed B0065. with this little description, pretensioner delay loop open, any idea what this means? any help would be appreciated!
    thanks guys!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,577
    Re: Air bag light on: CODE B0065
    The seat belts, buckles and tensioners are part of the air bag system. Before you start throwing money at sensors and parts, try this:
    Key:OFF. Fully - all the way to the stops - extend and retract the shoulder and lap belts several times. Buckle and unbuckle the belts several times. For more black magic, operate the seat and headrest adjustments to their travel limits several times. Reset the seats to your personalization settings.
    Turn the Key:ON and cross your fingers.
    thegreatgazoo likes this.
    Sep 2011
    Minnesota
    24
    71
    hey sub thought you would want to know, that worked! sorry it took me so long to get back to you i havent been on here in forever
    Feb 2006
    56,577
    Thanks............Sometimes blind luck and superstition wins out over skill and science.
    ffbuzz is offline Cadillac Owners Member
    Automobile(s): 2004 Seville SLS, Previously owned 92 DeVille, 95 SLS
    Mar 2014
    CT
    45
    3
    I just stumbled upon this post. Should i exercise both the driver and passenger belts and seats?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Don't bother with the belts. I've now had the retractor covers off of the belts in a '99, '00, '01, and '03. There are no electronics/wires involved, they will not set a code. The only electronics on the buckle assembly are for the pretensioners, nothing to the buckles themselves, other than the sensor on the drivers side that detects if the belt is buckled or not, and illuminates the belt warning on the IPC.
    Moving the seats back and forth moves the under seat wires and connector for the side impact airbag. You can either move the seats, or reach under and move them around yourself. That usually takes care of it.
    You only need to move the seat on the side setting the code.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,562
    Don't bother with the belts. I've now had the retractor covers off of the belts in a '99, '00, '01, and '03. There are no electronics/wires involved, they will not set a code. The only electronics on the buckle assembly are for the pretensioners, nothing to the buckles themselves, other than the sensor on the drivers side that detects of the belt is buckled or not, and illuminates the belt warning on the IPC.
    I don't know -
    we ARE dealing with Sub's VOO-DOO here -
    and you know what could happen if you don't follow directions - EXACTLY -
    Sep 2010
    East Boston MA.
    29
    26,325
    thegreatgazoo's Avatar
    thegreatgazoo is offline Cadillac Owners Member
    Automobile(s): 2005 cts
    Mar 2014
    48
    28
    Hey SUB I got this code after having my car detailed. found a plug loose under driver seat. most likely knocked loose when they vacuumed under the seats. Thanks for the tip on what to try.
    Feb 2006
    56,577
    Gotcha .............. the underside of our seats looks like a mixed snake cage at the zoo - gotta check everything.
    Post #4
    sdwMD is offline Cadillac Owners Member
    Automobile(s): NONE
    Jul 2016
    South Carolina
    53
    You are correct with your repair method!!! 2004 DHS Service AirBag B0065 code. Did as stated & light reset!!! THANX A BUNCH!!!
  14. Remove Advertisements
