Check Fuel Gauge message
Results 1 to 15 of 15
Like Tree5Likes
  • 3 Post By MoistCabbage
  • 1 Post By stsuk
  • 1 Post By supah_arod
  • 1 Post By naif
Cadillac Seville / Cadillac Eldorado Forum Discussion, Check Fuel Gauge message in Past Cadillac Vehicle Discussion; Today, before i got to fill up my tank. A CHECK FUEL GAGE message showed up on my display screen. ...
    supah_arod is offline Cadillac Owners Member
    Automobile(s): 2003 Seville SLS
    Apr 2012
    Irving
    31
    29
    Today, before i got to fill up my tank. A CHECK FUEL GAGE message showed up on my display screen. So i figured after i filled the tank, it would probably go away. And it didnt. Any ideas? I drive a 2003 cadillac seville. Thanks for any help.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Re: Check Fuel Gage message
    Do you have the instrument panel display set to only show the digital readouts, and not the analog gauges? If so, the fuel gauge is not visible, and that message will display when you are low on fuel.
    supah_arod, supah_arod and bwv565 like this.
    stsuk's Avatar
    stsuk is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Crimson Pearl STS 'W'
    Oct 2010
    Newcastle upon Tyne, England,
    42
    266
    That comes up after the 'low range' message on my car,only seen it once but it went away on a full tank.
    bwv565 likes this.
    Apr 2012
    Irving
    31
    29
    Thanks for making me feel like a dumbass lol. I was messing with the metric/standard button and the display button this morning while i was stuck at a light. I dont know why i didnt think of this. Thanks though. I appreciate the help.
    bwv565 likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,897
    Quote Originally Posted by supah_arod View Post
    heh, heh..................You're not alone !
    Sep 2010
    East Boston MA.
    29
    26,325
    No problem, it's the simple stuff that gets you sometimes.
    ThumperPup's Avatar
    ThumperPup is offline Cadillac Owners Master
    Automobile(s): not anymore 2007 Lexus ES350
    Mar 2009
    Murray/ Snowbird Utah
    37
    7,696
    if you are waiting beore filling up till you see the low fuel rang msg or anything along those lines you are waiting to long
    might want to stop going that low
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    I think (not sure) check fuel gauge comes up around 1/4 - you get another message when it hits the bottom of the gauge.
    CHECK FUEL GAGE - 50: This message will appear
    when the fuel supply is less than 5 gallons (18.9 L) and
    the display is turned off. A single chime will also sound
    when this message is displayed.
    FUEL LEVEL LOW - 11: This message serves as a
    warning that the fuel level in the tank is critically low.
    Stop for fuel soon. A single chime will also sound when
    As always, read the manual...
    bwv565 likes this.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    Re: Check Fuel Gauge message
    ah ok cool i didn;'t know this
    so if your using the digital only and not using the analog at all
    then once it hits down to the last 5 gallons check fuel guage will come on
    but it won;'t come on like that if its in analog mode ?
    Sep 2010
    East Boston MA.
    29
    26,325
    Yup.
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    cool im at half a tank now i guess ill turn it off to digi only and see if it comes up
    so far something els that has been bugging me for a year about the msg center is if i leave the gas cap or or even when i had a bad gas cap that i found out about when i went in for E-check last year
    i never get the check gas cap msg i thought that was something that was on 98-04 Seville but wondering if it is only on some of them perhaps
    Sep 2010
    East Boston MA.
    29
    26,325
    You'll also get the check fuel gauge message instantly if you switch to digital only, after the gauge is below 1/4.
    As for the gas cap message, it doesn't come on right away if the cap is left off, otherwise you'd get the message every time you filled up. I'm not sure if the exact conditions for it to display, but if you left it off long enough, it should come up.
    Mar 2011
    1,277
    Conditions for Running the DTC
    DTCs P0107, P0108, P0112, P0113, P0117, P0118, P0122, P0123, P0125, P0131, P0132, P0133, P0134, P0135, P0141, P0151, P0152, P0153, P0154, P0452, P0453, P0503, P1111, P1112, P1114, P1115, P1133 or P1153 are not set.
    Battery voltage is between 10.5 and 17.5 volts.
    Barometric pressure is more than 71.78 kPa.
    Fuel level is between 10% and 89.8% of full capacity for at least 3.2 seconds continuously. The time limit is required because fuel sloshing within the tank may cause the fuel level indication to vary outside the fuel level limits.
    Coolant temperature is between 2°C and 32.7°C.
    Intake air temperature is between 2°C and 32.7°C
    Start up coolant and intake air temperature are within 14.2°C of each other.
    Conditions for Setting the DTC
    The EVAP system cannot develop vacuum.
    Action Taken When the DTC Sets
    The PCM will illuminate the Malfunction Indicator Lamp (MIL) after two consecutive drive trips that the diagnostic runs and fails.
    The PCM will record operating conditions at the time the DTC sets. This information will be stored in the Freeze Frame and Failure Records.
    A first failure of this DTC will store in Last Test Failed but not History.
    P0440 (large leak) triggers the message. P0442 doesn't (small leak - cap almost tight)
  16. #14
    ThumperPup's Avatar
    Mar 2009
    37
    7,696
    i have left it off purposly for drives like last time i did i think it was leaving cleveland to dc stoped about 120 miles into the trip fro gas and no msg
  17. #15
    bwv565 is offline Cadillac Owners Enthusiast
    Automobile(s): HAD a miserable Catera and even worse 2003 STS
    Jan 2013
    Toronto
    603
    You're not alone. Exact same issue for me this morning, and I also switched the display from metric to standard. Then the Low Range message appeared, so I will fill up the car and hopefully that will take care of it. Thanks.
  18. Remove Advertisements
