Hot Northstar - Please help !
Page 1 of 14 1234567891011 ... LastLast
Results 1 to 15 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; ok my 1998 seville sls is getting hott then cooling off i changed the thermostat flushed everything blew out the ...
    tmaff7 is offline Cadillac Owners Member
    Automobile(s): 98 seville
    Apr 2012
    27
    5
    ok my 1998 seville sls is getting hott then cooling off i changed the thermostat flushed everything blew out the lines still does it at idle it runs normal and while driving...when i stop at a light or in traffic it goes to 3/4 n then start to drive and it goes rite back down please...helppppppppppp!
    it also has a bypassed heater core idk it that makes a difference?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you check the purge line for flow?
    Is the water pump belt and tensioner/pulley in good shape, belt not slipping?
    Are you losing coolant?
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Purge line: check it
    Leaks of coolant: check, thoroughly
    Block test: Just get one done
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: hott northstar helpppppp!!!!!!!!
    It stays cool on the move and only heats up while standing?
    Possible fan issue.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Yeah that is exactly what I was thinking, if it getting hot while standing then your fans are not working. Start with the most obvious things: FUSE. Pull your codes, you should have a code for it (I don't remember exactly what code but one should be ...fan control something).
    69
    82,180
    Quote Originally Posted by Aztec ETC ECS View Post
    Possible fan issue.
    Or maybe a condenser full of bugs?
    That said, I'd still do a block test.
    Apr 2012
    27
    5
    The fans work perfect the belt an tEnsioner is good shape today it got red hot n i shut it off its very frustrating the car will not get hott even at over 100 mph nothing stays in the middle
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    Post a picture of the temp gauge while the engine is "red hot".
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by tmaff7
    Wow, I completely missed that. Sorry.
    Feb 2012
    NYC
    50
    1,948
    From what you're describing, it doesn't sound like the fans are working perfectly. Maybe they're only running at low speed.
    What is the air temp where you live?
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Sounds exactly like my 2000 with a blown head gasket.
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by Faded Crest View Post
    Really? You could take it up to 100MPH with a bad HG without a problem?
    Usually it could idle for hours and overheat in 10-15 miles on the open road w/bad HG's.
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    Sound exactly like a car with non-functional cooling fans.
  16. #14
    Apr 2008
    North Carolina
    45
    3,222
    I missed the 100 mph comment. I never tried that. But mine will overheat at idle, but not while moving.
  17. #15
    Apr 2012
    27
    5
    Yea 100 plus no problem hr on the highway no problem two minutes at a red light ding ding ding coolant hot sstop engine
  18. Remove Advertisements
