Hot Northstar - Please help ! - Page 4
Page 4 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 46 to 60 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; It's not "normal". Mine NEVER moves, but I wouldn't panic at this point....
  1. #46
    68
    81,913
    Re: Hot Northstar - Please help !
  2. #47
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    I'm not sure if it went to one o'clock when I got off the exit and stopped at the first light but I noticed it while I was driving and it didn't go back to normal till I got home and let it idle with AC off for a minute or so.if the temps stay up while driving what is the cause of that?
  3. #48
    68
    81,913
    If the temps stay up while driving it could be many things.
  5. #49
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    What's some off the simpler things to check.purge flow is good and not losing coolant.lately when I stop at a light it will go up some and it will take a while to go to normal even after driving but today it went to one o'clock while after driving from a stop light but I got home soon as it went up so not sure what would of happened if I kept driving.
  6. #50
    68
    81,913
    Quote Originally Posted by sts 03 View Post
    Cap holding pressure, belt tensioner, condenser fins clean, thermostat, air dams in place.
  7. #51
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Where are the air dams?
  8. #52
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Re: hott northstar helpppppp!!!!!!!!
    The plastic air deflectors/flow formers at the sides, as well as above and below the radiator. The upper "radiator sight shield" and the lower "splash shield". They're a part of the cooling system airflow control system to insure airflow, whether from vehicle motion or fan effect, goes through the radiator fins instead of around.
  9. #53
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Oh damn when I got the car it didn't have the splash sheild on the bottom but the temp never rised especially how Hot it was last summer , never moved of the half way mark till this past spring when it wasn't even Hot outside.I guess I'll start with the cheap and easy stuff first like cap and thermostat.would the pump or belt cause ever temp to go up and down while moving?
  10. #54
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Are those rubber flaps on the side of the radiator part of the air damns? Also this didn't start recently till after I got a coolant flush when they changed the tranny
  11. #55
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes, they channel air through the condenser and radiator.
  12. #56
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Oh ok the one on the divers side that attaches to the frame/body of car was disconnected on one side, would that be enough to make the temp rise
  13. #57
    68
    81,913
    Probably not.
  14. #58
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    If the purge line is flowing does that mean the water pump is working?
  15. #59
    68
    81,913
    Yes.
  16. #60
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes. If the pump is spinning, and not making noise or leaking, it's "working".
    Oops, Ranger beat me.
  17. Remove Advertisements
