Hot Northstar - Please help ! - Page 3
Page 3 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 31 to 45 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; So it is normal for cars with the analog temp gauge to go to the 5/8 mark sometimes? I have ...
  1. #31
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Re: Hot Northstar - Please help !
    So it is normal for cars with the analog temp gauge to go to the 5/8 mark sometimes? I have not driven my '98 yet so I am not familiar with that type. Too bad you can't add the eng. temp parameter to the DIC.
    Actually I remember Sub posting that he had a diagram of the analog temp gauge on his profile, so I just looked at it.... I had no idea that the normal range went so far above half.
    sts 03, here is Sub409's diagram in case you want to check it out...
    http://www.cadillacforums.com/forums...y-numbers.html
  2. #32
    68
    82,072
    Quote Originally Posted by Faded Crest View Post
    Mine never budges off 12:00 for whatever that's worth.
  3. #33
    Apr 2008
    North Carolina
    45
    3,222
    My '94 Eldorado runs between 198-218 or so while in motion but will creep into the 225 range when idling... So on the analog gauge it would be approaching the 5/8 mark according to Sub's diagram.
  5. #34
    KNCadillac8898 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Deville DTS; Blue Ice Metallic
    Dec 2010
    Massachusetts
    27
    889
    I'll chime in about my '05. Exactly like Chris said on the last page, mine has popped slightly passed the 12 position before on hot days in stop and go traffic and will drop back down to 12 again. This never happens unless it's over 75 degrees outside and I'm in city traffic for an extended period. I've only noticed it on a total of three occasions. It's almost funny because if you keep your eye on the needle you can see it moving back in forth. The last time it happened I drove in city traffic almost non stop for a period of 4 hours in around 80 degree weather. The next morning I drove my normal route and the temp never went above 12 o'clock.
  6. #35
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    In mine, I've only ever seen it go one or two needle-widths above the middle with the engine running. I've seen up to the first tick mark after a turn off/hot soak for ~5 minutes (but then quickly coming down when the engine restarts).
  7. #36
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,248
    Remember: With some A/C function set in the HVAC, fans run in SLOW all the time, so unless it's 110 in El Paso you should see the gauge sit at just about 12:00. With the HVAC OFF fans are controlled by the ECT, so the normal cycle in heavy traffic would be between 12:00 and about the first tick past..... ~200 to 224 and back, as long as you were stuck in traffic.
    If you have the urge, you can do the same thing in the driveway - pop the hood, HVAC OFF, engine idling. Cover the condenser with cardboard. Watch the coolant temp rise and note where, on your gauge, fans go to SLOW. If you persist, fans will go to FAST - then pull the cardboard.
  8. #37
    Apr 2008
    North Carolina
    45
    3,222
    I've been kicking around in my cheapy '98 ESC "project car "for the past 2 days. It is already in the 90's here. It stays at 12:00 unless idling still for 15 minutes or so... Then it creeps up to probably halfway between 12:00 and the 5/8 mark and goes back down immediately when I move. My A/C is not working because one of the lines is bad... But I also noticed that if I move my head way over to the left so I am looking at the gauge straight on, it is actually almost a needle width above 12:00 all of the time, but appears to be 12:00 when my head is in it's normal position.
  9. #38
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    There are pictures in Northstar Performance forum sticky post : http://www.cadillacforums.com/forums...ling-fans.html
    The gauge between 4/8 and 5/8 mark indicates 224 degrees f according to my scanner - and it's perfectly OK for a normal car to creep up to this point under heavy duty conditions(: hot ambient temperature with A/C on. The A/C condenser alone generates lots of heat - and it's no help when it becomes hotter outside) or electric fan operations(: goes low at 224f and fast at 236f, stops at 213f or 45+mph)
  10. #39
    Apr 2008
    North Carolina
    45
    3,222
    Quote Originally Posted by maeng9981 View Post
    Good to see you around! I've noticed you haven't been posting as much lately. Thanks for the link too... After reading that, I guess splitting hairs over a needle width is silly.
  11. #40
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Things have been busy lately with everything....! Thanks. Yeah, do not worry about slight movements. It really irritated me when I first got my Seville, but I got used to it and now I use it as a sign of fan operation. The needle hasn't touched the 5/8 ever since the repair (except at the startup sweep!), but with Texas summer heat (A/C on full at 60F) and with the major construction on the busiest DFW highway, I saw the needle between 4/8 and 5/8 almost everyday last summer.
  12. #41
    Apr 2008
    North Carolina
    45
    3,222
    Well you are one of my "heroes" for successfully tackling that head gasket job at your age and level of experience. It makes me smile when I think of your "victory scream" when you started it up for the first time after the fix.
    I hate that the DIC is not "hackable" like the earlier Devilles, but I suppose once you are used to your car and how the temps display that should be enough. I tend to keep the Temp on the DIC display on my '94 most of the time. I am not really "worried" about it, but let's face it, the issue is probably in the back of most of our minds.
  13. #42
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    I wasn't expecting it to start right up! I was so happy that day. That was after 8 hours of work just installing the drivetrain back in the car, changing all the fluids and trying to bleed brakes.
    Funny how when I first got the Seville I was okay with my Deville going up to 222F occasionally but was not okay with the needle going slightly over half. I blame modern cars having dumb gauges, since I was so used to the temp gauges staying dead center between C and H no matter what the actual temp is. That kinda spoiled me and it's part of the reason why I was not happy with the fluctuation.
    Faded Crest and Faded Crest like this.
  14. #43
    Mar 2011
    1,277
    If you want to know about damped gauges, I drove a 2012 Ford recently (for work) - the middle tick on the gauge goes all the way from 55-105 degrees C (!)
  15. #44
    Apr 2008
    North Carolina
    45
    3,222
    ^^^ Yeah, I think Fords are some of the worst for dampened gauges. My box truck is ridiculous, too..
  16. #45
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    Today I was driving temps in the low 90's ,I was driving on the highway for about 15 minutes and when I got off the exit for my house my temp went to the one o'clock mark while I was driving not at a light.when I got home and turned the AC off then it went down.since I had the car it never went that high especially while driving , which lately I've notice someone the needle goes up and down a little while diving .is that ok for it to rise to one o'clock while driving and what temp is considered running Hot?
  17. Remove Advertisements
