Hot Northstar - Please help ! - Page 2
Page 2 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 16 to 30 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; Have you checked the drive belt tensioner? Sounds like a slipping drive belt could be a possibility....
  1. #16
    68
    82,076
    Re: hott northstar helpppppp!!!!!!!!
  2. #17
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    58
    1,693
    Quote Originally Posted by tmaff7 View Post
    The fans work perfect the belt an tEnsioner is good shape today it got red hot n i shut it off its very frustrating the car will not get hott even at over 100 mph nothing stays in the middle
    You do know the water pump is driven by a small belt on the drivers side of the engine, not by the large serpentine belt on the power steering pump end. Totally different belt and tensioner.
  3. #18
    tmaff7 is offline Cadillac Owners Member
    Automobile(s): 98 seville
    Apr 2012
    27
    5
    ok i just checked the line that i think is the perge no flow maybe air?or water pump fail? lmfao help how do i bleed it?
    just checked the perge line no flow just air maybe w/p or block helppp how do i bleed it?
  5. #19
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    This system is self purging...unless the purge line is clogged.
    The purge line is the small diameter hose that runs between the upper part of the surge tank and the hollow bolt/nipple on the water pump cover. To check if it's clogged:
    -With the engine OFF AND COOL, remove the surge tank cap.
    -disconnect the purge line from the surge tank, and place it in the tank opening.
    -Start the engine. There should be a slow, steady flow of coolant from the purge line. If not, either the line or the hollow bolt/nipple is clogged.
  6. #20
    Mark C's Avatar
    Jul 2007
    58
    1,693
    The GM stop leak pellets will clog up the hollow bolt where the purge line attaches to the thermostat housing, if theres no flow, get a long nail (>2" long), or a peice of coat hanger wire, or a drill bit to clear out the inner diameter of that bolt. In really bad cases the hose itself gets plugged, so disconnect both end, and make sure you can blow thru the hose. Be caseful of the nipple on the surge tank, old plastic gets brittle with heat over time. Theres a small restrictor in the surge tank nipple, so if you go poking into it, make sure your doing it with something small enough that it doesn't tear the restrictor apart.
  7. #21
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Usually, with a clogged purge, the temp will just rise & not come down and there should be no heat, almost the same symptoms as a broken WP belt.
  8. #22
    Apr 2012
    27
    5
    What till you hear this lol changed the rad. Cap now no problem $4.50 imagine that
  9. #23
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,256
    Yep ^^^ With a bad radiator cap the coolant will boil at about 218 - 220 if it's a 50/50 mix. With a good 16 - 18 psi cap the coolant will not boil until above 265 degrees. At the maximum concentration recommended by GM - 70/30 - coolant at 18 psi boils at 276 degrees.
    Considering that, with no A/C function set, fans do not even go to SLOW until 224, with no pressure in the system it's easy to boil the coolant during normal driving.
  10. #24
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    My car does the usual at the light where the temperature goes a little past the half way mark then when I drive it goes back to the middle but yesterday when I started driving it didn't go back to the middle mark for about ten minutes of driving.is that normal or Sign ofsomething yet to come
  11. #25
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Quote Originally Posted by sts 03 View Post
    Hard to say... Have you done all the checks posted here?
  12. #26
    naif is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 Seville STS, 2004 Deville DHS
    Mar 2011
    near Virginia Beach, VA
    1,277
    Stop and go traffic, A/C on? I wouldn't worry.
  13. #27
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Yep stop and go traffic AC was on it just went almost to the next line past the half way mark but It always go back when driving it did eventually after 5 -10 minutes driving.so its normal to stay a little past the middle even when driving giving the conditions
  14. #28
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    that sounds normal... it should rise a bit then go back to the middle under normal operation in the summer (or warmer climates)
  15. #29
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Thanks: wiping sweat off of forehead:I just haven't seen it take that long to go back to middle while driving
  16. #30
    Feb 2006
    56,256
    Clean the bugs and crap off the front of the A/C condenser (in front of the radiator) - carefully use a bristle brush vertically to brush out the fins.
  17. Remove Advertisements
