Hot Northstar - Please help ! - Page 14
Page 14 of 14 FirstFirst ... 4567891011121314
Results 196 to 198 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; The tabs would "probably" sit in the bottom of the tank. They may have plugged up the supply end. I'd ...
  1. #196
    68
    82,083
    Re: Hot Northstar - Please help !
    The tabs would "probably" sit in the bottom of the tank. They may have plugged up the supply end. I'd pull it and flush that crap out. Hard to say if it is clogging the radiator or heater core. Not real common, but has been known to happen.
  2. #197
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    Well my radiator was just replaced and mechanic had to replace the reservoir earlier this spring.I thought I read somewhere that the tabs can clog the heater core.its still baffling me why the temp started fluctuating a year after I had the car.
  3. #198
    68
    82,083
    Correct.
