Hot Northstar - Please help ! - Page 12
Page 12 of 14 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 166 to 180 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; If the tensioner pulley was going bad would that cause the needle to go up some on the highway when ...
  1. #166
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
    If the tensioner pulley was going bad would that cause the needle to go up some on the highway when going up hills .also I hear this rattling/tapping noise sometimes when at highway speeds that sounds like it comes from the divers side engine compartment.
  2. #167
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Not unless the pulley was seizing, and causing the belt to stop moving.
    There's pretty much no way you'd hear a ticking pulley bearing from inside the cabin at highway speeds.
  3. #168
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    The rattling/tapping noise sounds more in the driver wheel area to me, but haven't heard it lately.if the tensioner/pulley its wobbling back n forth should I change it or inspected better.
  5. #169
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I replaced the purge line and clamps the other day yesterday it started leaking from the meatal nipple side.should I tighten the clamp till where the hose can't spin around the nipple at all?I just don't want to over tighten it.
  6. #170
    68
    82,081
    Re: Hot Northstar - Please help !
    Inspect it. Maybe post a video of it if possible.
    If it's leaking, tighten it.
  7. #171
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Ok so I inspected the tensioner pulley again today it has very little play when I try to wiggle it and when I spin I didnt hear any clicking noises out rattling noise but I can hear it spinning.also this is off the topic but when I had the hood up I can hear like a ticking/tapping sound and a vacuum/suction sound.the vacuum sound like its coming from the manifold power steering pump area.the ticking tapping sound sounds like somewhere up to valve cover/ injector area.
  8. #172
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,264
    The tensioner pulley should have NO side to side play and no clicking.
    I believe we have discussed the vacuum noise at the front (passenger) end of the intake manifold. If you can locate the noise using a piece of hose stuck in your ear - stethoscope - then you may find it's the PCV dirty air line or an elbow.
    2003 has the manifold overpressure valve at the throttlebody end.
    The ticking/tapping noise - some busy mechanical noise is always normal, but when did you last change the oil and filter, and what did you use ?
    Remember: there are 3 chains, 4 cams, 32 roller cam followers and 32 valves happily slapping around inside those cam covers.............as well as 8 fuel injectors ticking away. (2000 and later engines..........)
  9. #173
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    The pulley wasn't making a clicking sound , just sounded like a pulley being spun around a bolt is best I can describe .so if the vacuum noise is coming from the pvc dirty line /elbow does that need to be changed or is it normal.
  10. #174
    Feb 2006
    56,264
    If you can hear/see/feel a vacuum leak, it's not normal and it WILL cause various degrees of poor engine performance.
  11. #175
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    The suction noise sounds like it's coming from where the pvc line connects under the intake near the power steering pump.can I spray brake fluid or throttle body cleaner to see if the rpm increase or do I have to use carburetor cleaner?
  12. #176
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I spayed carb cleaner rpm didn't go up.it sounds like it's coming from in the intake manifold, maybe it's just the normal sound of the air being sucked through the engine (can really only hear it with hood up.car seems to be to be driving fine overall , sometimes when I have to come to a quick stop the rpm drop down to close to 500 the go right back up?
  13. #177
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Today I went on the highway and did a few wot in 2nd gear from 40mph to 70 mph after the last one the needle went up just before the first tic.as soon as I put it back in d the needle went back to the middle , on northstar performance it says after doing a few fast runs to 70 mph the needle shouldn't go past the 5\8 mark.this is to test for head gasket leak .remind you it went right before the first tic and as soon as put back in d it went right back to middle.is this normal for the needle to rise some when doing wot's in 2nd on a Hot day with a/c on?
  14. #178
    Feb 2006
    56,264
    Is it normal for you to sweat a bit during a dead run in 100 degree temperatures ?
    If you're going to do a few WOT's or any crazy maneuvers involving maximum engine performance, turn off the A/C and any accessories - ANY accessories - under maximum performance conditions the engine has enough work to do without keeping you cool.
  15. #179
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Thanks yeah I was wondering of I should of turned the AC off .speaking of the AC does it lower engine performance and mpg when in use?
  16. #180
    Feb 2006
    56,264
    Of course. The compressor uses 2 - 5 HP any time it's running as well as increasing the electrical load on the alternator and the heat load on the cooling system. It takes gasoline to supply that lost HP.
  17. Remove Advertisements
