Hot Northstar - Please help ! - Page 11
Page 11 of 14 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 151 to 165 of 198
Like Tree2Likes
Cadillac Seville / Cadillac Eldorado Forum Discussion, Hot Northstar - Please help ! in Past Cadillac Vehicle Discussion; Yeah I for those but its fine drove it, but the temp still fluctuates some on hills on the highway....
  1. #151
    sts 03's Avatar
    sts 03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 sts
    Oct 2011
    d.c metro area
    37
    1,754
  2. #152
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I was just under the hood and I found that one of my o2 sensors was plugged half way in.could that cause my car to run hotter on hills at highway speeds
  3. #153
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: Hot Northstar - Please help !
    No.........
  5. #154
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Ok so drained the fluid and filled with 50/50 just In case the last idiots that changed the fluid when they did the tranny didn't mix it right.I doubt that is what is causing the temp to rise some on hills but that is one of the steps in the fsm to check fluid concentrate.have not drove it yet, we will see what happens.
  6. #155
    68
    81,891
    Coolant concentration will not affect the operating temperature (unless maybe it is 100%).
  7. #156
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Yeah I doubt that's the problem but that was the fourth or fifth step in the manual .
  8. #157
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by sts 03 View Post
    We're still not sure that there even is a problem.
    The only problem that Ivan think it 'might' be is early stages of HGs. (sorry had to say it)
  9. #158
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    Yeah I would to hate to have that happen.it isn't definitely running Hot but its still concerning me that it does it on the highway usually on hilly roads when it never moved off the middle before.it didn't start doing this till after I had the coolant flushed and tranny swapped out.so i'm wondering if they didn't do something right .if I pull the purge line off and have someone give it gas should the flow increase? Also with Hg failure would I be loosing coolant?
  10. #159
    68
    81,891
    Eventually, but you might not in the early stages.
  11. #160
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    I was looking at the tensioner pulley for the water pump and while the belt is spinning the tensioner pulley wobbles back and forth , is this a problem.
  12. #161
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Yes. If the pulley is wobbling, or the tensioner arm appears to be "jumping", the pulley needs to be replaced.
    Remove the belt and turn the pulley. How does it feel? Is there play in the bearing?
  13. #162
    Feb 2006
    55,850
    "Wobbles back and forth" - as in: side to side - axial wobble, or up and down - radial wobble ?
    I thought you were just into this assembly ?? You didn't grab and spin the tensioner pulley ???
    (Sorry, MC)
  14. #163
    68
    81,891
    It's spring loaded so the tensioner may move some. That's normal, but the pulley should not "wobble" laterally. That would indicate a very worn bearing.
  15. #164
    sts 03's Avatar
    Oct 2011
    d.c metro area
    37
    1,754
    It seemed fine when I checked it maybe I didn't check it good enough it was a 100 degrees out that day.but it wobbles like towards the front to the back., its hard to tell but its a definite wobble.
  16. #165
    68
    81,891
    Front and back is OK.
  17. Remove Advertisements
